Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to pair my blueant supertooth st3 .
I no longer have the manual , but I got a new phone.
Anonymous
Level 2:
  • Expert 6 Answers
  • Posted on Aug 18, 2009
Anonymous
Expert
Level 2:
Answers
6
Questions
0
Helped
30204
Points
106
Code is 0000 make sure you press the green button to turn on the blue tooth light on the Blue Ant, while you enter the pin (don't hold it down, just make sure it's on before you finish entering it).
BlueAnt Supertooth 3 ST3 Bluetooth Speakerphone. How do I get English back on it please?
Question edited for clarity.
How do I change the language on my BlueAnt st3? November 2, 2021 by anstoall2021
How do I change the language on my BlueAnt st3? From off, press and hold the On / Off button until the Bluetooth® indicator turns blinking red/blue. (The kit is now in pairing mode). Please be patient because the Commute 3 has 12 languages and it will cycle all available languages.
How do I reset my BlueAnt ST3? Reset the BlueAnt device. Press and release the "Vol +," "Vol -" and "Multi-Function" buttons all at the same time. The volume buttons are located on the side of the BlueAnt, while the Multi-Function button is on the front. The BlueAnt resets and clears the existing pairing list.
How do I remove a BlueAnt pair list? On your phone bluetooth menu, search for devices and select BlueAnt ST3 then enter 0000 as pincode. Press the MFB until the LED blinks red/blue. Note: Blackberry and Smart phone owners please refer to section F of user guide. Alleant Phonebook transfer will be initiated.
How do I pair my Supertooth 2? Pairing Mode.
Turn on its Bluetooth function then execute a Bluetooth search so that it will be able to search and find your Supertooth II. When the phone displays the list of the Bluetooth devices it has found, select the name of this kit (Supertooth II). 5. When the phone asks for a passcode, enter "0000".https://www.google.com/search?q=blueant+st3+change+language..
9helpful
How do you pair an iPhone with the blueAnt st3?
Step 1: Activate Pairing Mode on the Supertooth 3
Make sure the Supertooth 3 is turned off.
You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down.
With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue.
The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken.
The Supertooth 3 is now in pairing mode.
Step 2: Apple iPhone
Now you need to use your iPhone to search for Bluetooth devices:
Select Settings.
Select General.
Select Bluetooth.
Wait for your phone to search for devices, then select your BlueAnt device from the list.
If you are prompted for a PIN, enter 0000 (four zeros).
Select Connect.
Your BlueAnt device is now paired.
8helpful
How do I pair it to my droid two
Hi Amygreb4037
According to BlueAnt this is the correct procedure:
Firstly:
Make sure the Supertooth 3 is turned off. You can tell if the Supertooth 3 is on or off by looking at the light on the front. If the light is on or flashing, then the Supertooth 3 is on: turn it off by holding down the Multi-Function button (the green button) for about 5 seconds, until you hear the voice announce that the Supertooth 3 is powering down. With the Supertooth 3 off, hold down the Multi-Function button for about 6 seconds, until the light on the front of the unit starts flashing red and blue. The Supertooth 3 will now prompt you to select your language: press the Multi-Function button when you hear your language spoken. The Supertooth 3 is now in pairing mode.
Then on your droid two
Go to the system menu and enable Bluetooth Go to your phone's Bluetooth menu. Select Add New Device. Wait for your phone to search for devices, then select your BlueAnt device from the list. If you are prompted for a PIN, enter 0000 (four zeros). If you are prompted to connect to the device, select Yes or Connect.
The two should then be paired and working.
More information can be found on BlueAnts website:
http://www.myblueant.com/knowledgebase/pairing/products/st3.php
I hope this helps.
I need a pass key
0000 is the passkey for blueant bluetooth products.
This link provides the step-by-step pairing procedure.
34helpful
2answers
Having trouble pairing phone with Blue Ant ST3
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol " and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Cannot pair blueant ST3 wih Nokia 6300
Reste the ST3 and then pairi again. It worked for me. Check this link:
http://www.myblueant.com/knowledgebase/reset/st3.php
Deven
437helpful
6answers
Blue Ant ST3 will not recognize 0000 passcode.
  2. Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
14helpful
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
Pair
Hi Cass. I had to same problem as I was used to using the original version. You need to hold the On button for 6 seconds, then follow the prompts. Go to the following website for the manual. Good luck !!
http://www.blueant.com.au/manuals/s3/S3_manual.pdf
Top Blueant Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
