Question about Plantronics Discovery 640 Wireless Headset
Earpiece vibrating & heating
My plantronics640 earpiece starts vibrating when I try to charge it then sometimes when its not charging it gets very hot when I haven't had it to my ear & wont stay charge that long. I don't have the manual for it anymore.
Do you know if the codes of the headsets are the same i lost mine and i need help
Posted on Aug 24, 2007
SOURCE:
How do i get the red light to show that the earpiece is charging
Do you have a spare cable to try charging it with?
Apr 17, 2016 | Radio Communications
Samsung galaxy s2 will not charge
Could be a battery problem, ut is usually a problem with the charge cable or connector. Try a different charge cable, they are usually Micro USB connectors, and check if the power (MaH) Matches what your phone needs. Otherwise you might need to repair the port. Try this.
http://www.youtube.com/watch?v=q4e-5xkhvHA
Jul 22, 2014 | Samsung Galaxy S Ii 2 Sgh-t989 16gb...
Hbs-700 won't charge
Here is a how to video to open up the earpiece and replace the battery if needed. While you have the earpiece open you can check the the battery with a volt meter to see if it's holding a charge. The stock battery for this earpiece is 3.7v and 195mAh.
LG Tone HBS700 730 repair mod and upgrade
Jun 28, 2014 | LG HBS-700 Bluetooth Headset
Whatdo i do if my skullcandy headphones dont charge?
Are these amplifing headphones or ? Most headphones use the devices power source to make the headphones work, they use very low voltage and various ohlms to make the earpieces vibrate and make sound. If they are not working try pushing the connection in all the way, or try another set of headphones to see if the problem is with the device. Sometimes we get defective headphones right out of the box, Skull Candy is usually very reliable and quality checked before shipping, but it can happen with all manufactures. Gool Luck.
Mar 15, 2011 | Audio Players & Recorders
If there is a battery in the earpiece; is it safe? There is some controversy about the safety of holding a cell phone to one's ear for extended periods; that's why I wanted an ear piece.
Yes it is perfectly safe. The easiest way to identify whether a bluetooth set is malfunctioning or unsafe is - HEAT. Normally batteries which are about to die or devices malfunctioning will heat up quickly when you charge it.
So unless you dont feel abnormal heat.. they are perfectly safe. Try to remove the BT earpiece when not needed. Your ear canal needs natural air flow. Blocking it with a prolonged use of a BT device could heat up the ear canal. That's where the problem starts! :-)
Mar 05, 2011 | Southern Telecom Emerson Bluetooth Headset...
Lost manual need to charge my earpiece
Need more information...what earpiece are you using? Does it have the same charging port as your phone? Chances are your earpiece charges through a micro-usb port. If this is the case, you can easily find a new charger that is of size micro-usb (that is the same size as the charger of most new cellphones).
Feb 28, 2011 | Cell Phones
Hi, i am using Nokia 9300. My problem is that even when i charge my battery to full capacity, it drains out after a few calls...if i dont make any calls, d battery lasts longer, not what it should though....
tray to change your battery first.if still like that, the damaged are in PA (power amlifier IC) that phone used to transmitting.the sign off PA not good any more: we feel heat on our earpiece when we make a call,some times there were a noissy sound on earpiece.
May 24, 2010 | Nokia 9300 Smartphone
Lg ku990 heats up.... i dont know why but every time i charge my phone it always heats up
LG phones have this weakness of getting heated up while charging and even sometimes while on a call. Try to put charging on the power socket that has enough grounding
Aug 09, 2009 | LG KU990 Viewty
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
I cant get my Mobile phone to find my bluetooth earpiece
no solution sorry
wait for another members
greetings from algeria ;)
Feb 01, 2008 | Nokia 6300 Cellular Phone
Plantronics Discovery 640 Wireless Headset Logo
128 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
