Question about Konica Minolta DiMAGE Z1 Digital Camera
Camera won't stay turned on
All of a sudden, my Z1 won't boot up and stay turned on. When I press the ON button, in either of the 3 modes (camera viewer, camera LCD or playback LCD) the zoom lens zooms out and then back in (as it should) but then shuts off automatically. None of the buttons work (while the camera is off, except, of course the ON/OFF button) and the camera shuts off as described before I can get it into the menu mode so I can do a factory reset. I tried new batteries, new SD card, checked the format of the SD card to verify the format was FAT16 not FAT32, checked the batteries to verify there fresh...but so far nothing works. Is there a hard reset procedure for this camera?
  • 944 Answers
If you need it you can get the user manual on this link; http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z1/D_Z1_E.pdf The hard reset involves dismantling the camera and un-soldering the memory/clock back-up battery from the main board (check page 112 under batteries). This battery needs replacing after around 3-5 years and is the most likely cause of your problem - they recommend getting it done at an authorised service centre which is good advice unless you have a lot of technical skill - quite a fiddly job to do and to get to - also professional tools are recommended in order not to damage the camera. Konica Minolta have now passed service responsibility for this camera to Sony - please post back with your location and I can try to find a convenient service centre. The back-up battery in question is probably relatively cheap (you would have to get the serial number from it for me to check for sure), but the labour involved in replacing it may possibly make the replacement a bit costly, but still should be much less than a new camera of the same quality. Hope this helps :)
Posted on Sep 06, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Sep 06, 2007
    Ps - a quick easy thing to try is to clean the terminals of the main battery compartment gently with a cotton bud/q-tip damp with gin. even if the terminals look clean, they can get a thin film of grease on them that causes power-up problems.
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
Tip
How to Take a Screenshot on Sony Xperia Z1
1) Go to the display or the screen in your Sony Xperia Z1 which you want to capture.
2) Take a screenshot. Press the Volume Down button on the side and the Power button for about 2-3 seconds. Make sure that both the buttons are pressed TOGETHER, otherwise it won't work.
3) View your screenshot. You will immediately hear a clicking sound, confirming that the screenshot has been taken. You may also see the text "Saving your screenshot" on your phone's display during the process.
To view your screenshot, click on the screenshot notification in the notification tray or simply go to your Photo Albums and you will find the screenshots in a folder named "Screenshots."
on Jan 10, 2015 | Sony Xperia Z1 4G LTE"
How to set the 10 sec timer on this camera
Press the MENU button, select "Drive Mode," then select the self-timer (one-handed clock). Start the self-timer by pressing the shutter release button.
Dec 17, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
How to operate self timer for take photo please...
Nov 01, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
How do I set the camera to delay taking a picture so that I can be in it too?
Sep 07, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
How to take my photo on delayed timer? Have been through the settings menu and cannot find a solution.
Press cursor-down (marked with a one-handed clock) to cycle through the different self-timer modes. Your choices are off, two-second delay, and ten-second delay. Start the self-timer by pressing the shutter release button.
Oct 13, 2009 | Fuji FinePix Z1 Digital Camera
My Fuji Finepix Z1 has suddenly gone to black and white
It's a setting.
Slide open the cover
Press the F key
Press the down 'cursor' key twice
Press the right 'cursor' key
Select STD or 'C' options for color pictures
Aug 03, 2009 | Fuji FinePix Z1 Digital Camera
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Viewfinder not coming on!
I found this "solution" on another site and it actually worked!
Turn the camera upside down. Now, with the device off, tap it a few times in your hand. Now, turn the device on in the viewfinder mode. Tap it again if the viewfinder isn't active.
Jan 22, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Pentax M20 Green Mode Stuck
i just had the same problem....
here's how i fixed it...
turn it on... then as it's loading up... hold the "menu" button
i think this forces it to stay on...
i changed the green button to be something else... not green mode
then i just turned it off and on again
Aug 20, 2007 | Pentax Optio M20 Digital Camera
Konica Minolta DiMAGE Z1 Digital Camera Logo
301 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
