Question about Panasonic CT-36HL43 36" TV
After power outage, tv doesn't turn on
My panasonic television (CT-36HL43) will turn on shortly, with black screen, then click three or four times, then turn off, the red light flashes on & off. I'll unplug it for a few minutes and it goes through the same thing again. A previous posted solution stated that it might be the Overvoltage regulator. If so, is it resettable? easily replaced?
  • goldcar Aug 17, 2007
    Hi DonL,
    It's blinking 6 times every 5 seconds. Thanks!
    Tom
    New Friend:
After home power outage my magnavox LCD 42inch flat screen tv will not power up
Posted on Jun 15, 2011
    Problem Solver:
  • 18 Answers
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Posted on Aug 17, 2007
  • Anonymous Aug 18, 2007
    Tom, locate IC4518. I do not have the schematic for this set but either that IC and or componants associated with it is the cause indicated by the LED blinking 6x.. Are you equiped to repair this yourself?
    Don
SOURCE:
I have a ct-36hl43 thyat when turned on it tries to come on but shuts down and the red power keeps blinking and the only way to stop it from blinking is to pull the wall plug whats the problem??
If you can find the Horizontal output transistor make sure it is not shorted, this set had a issue of repeated shorting of that part after just a few minutes and the cure for that is well known.
To trouble shoot you will need a volt/ohm meter and how to use it, the set if shorted will not always blow the fuse but will go into shutdown to prevent further damage.
Let me know your skill level and if able to use a meter etc or not.
Dec 10, 2012 | Panasonic CT-36HL43 36" TV
Television problem
HELLO!!
FROM WHEN ARE U FACING THIS PROBLEM ???
Dec 30, 2007 | Panasonic CT-36HL43 36" TV
Power surge-no picture or sound, just red blinking power light
Any malfunction associated with a blinking redlight usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | Panasonic CT-36HL43 36" TV
Tv - Has a bird in it
call the guy you got it from and give him the bird
Jul 03, 2009 | Panasonic CT-36HL43 36" TV
Panasonic CT-36SL14J White screen
my Panasonic CT-36SL145J won't turn on
Dec 25, 2008 | Panasonic CT-36HL43 36" TV
Panasonic CT 36HL42CF
same trouble ,the tree pronged square chip that you mension which is called horizontal transistor is busted again. try to check the plyback of your tv .maybe that parts have a problem.
Sep 29, 2008 | Panasonic CT-36HL43 36" TV
My tv dose not turn on
i have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent [email protected]
Dec 29, 2007 | Panasonic CT-36HL43 36" TV
Panasonic ct-36hl43 tv
This is usually down to a safety feature cutting out the Television from harming itself. Or quite possibly a fault that make it turn itself off - it may well be thinking it's receiving the command to turn itself off. Either way, it's impossible to find out without opening it up. A professional repair is the only way, check up on your warranty. You may want to plug it into a different power source, just on the off-chance that it may solve your problem - but don't get your hopes up.
Sep 07, 2007 | Panasonic CT-36HL43 36" TV
Won't turn off
it can happen due to overvoltage shutdown circuit. when voltage is too high, tv will shut down. it is possible that this specific model doesnt fit your local electricity network.
Dec 14, 2005 | Panasonic CT-36HL43 36" TV
Panasonic CT-36HL43 36" TV Logo
1,422 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
