Question about Toshiba Axiom 60GB HDD Satellite Pro 4300, 4280, 4260 Series (AXT0760) Hard Drive
Do you know ho to format a toshiba satellite pro 4300
Hi, just trying to format laptop, do you know the best way to do it?
  • 1 more comment
  • rossi_09 Aug 17, 2007
    thanks for the advice, i tried that earlier but would not let me run the format. Lucky though because as you pointed out i would need all the drivers....hahaha...dont have them.
    the laptop is just running very slow... thinking of upgrading the ram. only using 128 atm. there are no programs apart from windows XP installed on the computer. we had alot of virus/spyware on the comp before, think that maybe it could still be infected, although did clean it up.
  • Anonymous Mar 20, 2008
    plz give me toshiba satallite A135-s2386 all drivers
    plz send u this ID jayaramnd2001@yahoo.com
  • Anonymous Mar 21, 2009
    That registry cleaner that Noggin posted is advertised as freeware, but in order to actually clean the files you must register, which costs 30 USD.
    Does anybody know of a good registry cleaner that is actually free?
  • 944 Answers
What operating system are you using? If windows xp then just right click on the icon of the hard drive in "My Computer", select "format" and follow the instructions with all the default settings. Be aware that if you do this you will have to have your windows xp cd or a cd for a different operating system in order to be able to restart the laptop. You will have to reinstall the OS and then all the necessary drivers for the laptop and any software you are running. What exactly is causing you to wish to format? Usually there is an easier way to solve HDD problems. Please post back with more info
Posted on Aug 17, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Aug 17, 2007
    Drivers shouldn't be a problem if you need to go that route - they are available for download from the Toshiba support site - which model do you have? Here's the link in case you need it in future;
    http://www.csd.toshiba.com/cgi-bin/tais/...
    Other than that things to try;
    1. Uninstall or Delete anything you are sure you don't need from the machine. If not sure then leave it.
    2. Run "Disk Cleanup" from "Start - All Programs - Accessories - System tools".
    say yes to all options.
    3. Run Disk Defragmenter from the same location.
    4. Get rid of whatever antivirus software you have now. Download, update and then scan your laptop with the free anti virus, anti spyware and anti rootkit programs available from;
    http://www.free.grisoft.com/
    (they are very good - not just free crap)
    Follow the instructions in each of the three programs.
    5. Download and run a windows registry cleaner - this link takes you to a reasonable one;
    http://www.free-windows-registry-cleaner...
    6. Use the laptop for a couple of days to see how much it has speeded up. If it still is not back to what you expect then download and run a memory optimizer (here is one that is ok, but there are many more available if you don't like it much);
    http://www.softpedia.com/get/Tweak/Memor...
    7. If you are still not getting the results you want after a couple of days, then open windows task manager (right click on the clock on your desktop taskbar). Select the "Processes" tab then click on "CPU" (probably twice) to get the processor usage details - have a look for anything that has a number next to it that you don't know what it is - you should see "system idle process" taking up most of 100%, that is normal. Any others that are taking up more than 1 or 2 % - ask again and I can hopefully identify what they are and whether or not they should be running or removed.
    8. If you have a motherboard utility program that allows you to see the motherboard and CPU temperatures, check it and let me know what you get - although it probably won't list the RAM temperature, the others are a good indication if this is too high. overheating in summer is common in machines that have not been serviced for a while and can make them run painfully slow. If it is too hot I can talk you through the procedure to improve the cooling, although you would need to be confident working inside the laptop.
    9. After that it is probably time to start thinking about more RAM, give me the details of the laptop and especially the existing RAM and I could try to track down the best deal for you.
    Hope this helps - (Please info me which model you have as this would almost certainly help)
Ouch memory managers don't work very well at all. Turn off disk indexing and you will notice the speed increase when accessing the drive. Go into the control panel, administrative tools, services, and when you get the services window open look for "Indexing Service" right click it go to properties, and in the drop down menu select disabled. IF you for some reason get an error then also open up my computer, and right click your hard disk go to properties and there should be something there saying allow the indexing service to index this drive....uncheck that box. now after you get that done reboot, and notice the speed increase for hard disk access time. Older Toshiba Satellite Pro's 4xxx series have a max of 320MB of ram, and max of 256MB stick of ram so don't go buying too big.
Posted on Aug 23, 2007
I have problum dvd writer
is the DVD writer the original unit in the notebook ? if not usre, refer to the manual -- if you dont have manual, go here (it will cost a little )
http://user-guides.co.uk/cddownload/Toshiba/ToshibaSatellite/Toshiba-Satellite-Pro-A100-TOSHIBA-Satellite-A100-Satellite-Pro-A100-161676.html
before you format, try replacing the DVD writer another unit similar
buy recovery CDs here
http://restore-disk.com/restoredisks/Toshiba/ToshibaSatellite/Toshiba-Satellite-A100-S8111TD-with-Intel-Celeron-Processors-XP-Driver-421349.html
i would restore the notebook to factory settings -- this is the best option in getting the computer back to the way it worked originally going to the factory settings management portion in the system and or use your recovery CDs to format and re isntall everything
Oct 15, 2010 | Toshiba Satellite A100-S8111TD Notebook
Ho do i turn on my bluetooth for the L300D?
Toshiba Satellite Pro L300 PC Notebook does not have Bluethoot device inbuild. You have to connect a external device for use.
Thanks.
Feb 03, 2010 | Toshiba Satellite Pro L300 Notebook
Need toshiba satellite 4300 display and sound driver (XP)
You can get all your drivers from Toshiba's website.
http://www.toshiba-europe.com/bv/computers/sns/index.asp
Jul 09, 2009 | Toshiba Satellite 4300 Notebook
SOUND DRIVER
hi i have toshiba SATELLITE PRO A 120 LAPTOP MODEL NO PTA 83L-08L02L .after formating i lost sound now not any drivers is compatible for my computer .and i dont have recovery cd also please help
Sep 08, 2008 | Toshiba Satellite A100-S8111TD Notebook
Need to format harddrive on Toshiba Satellite Pro 4300
here are a couple of links so ya can get a handle on things.... Just follow the instructions ya be all good.... http://72.14.253.104/search?q=cache:0sWcmSlxdlwJ:lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php+tutorial+to+format+laptop+hard+drive%3F&hl=en&ct=clnk&cd=2 www.youtube.com/watch?v=CEhbmJbAjPw
Aug 17, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
I'm using a toshiba 4300 satellite pro 4300 series laptop, i don't know how to dim the screen. i've tried pressing Fn and various F keys to no avail. Please don't reply in computer language because i'
Hi. According to the user manual, the Fn + Esc (key)displays the screen brightness pop-up window which are: super bright; bright and semi bright. You may want to check out Toshiba 32-bit Online User's Guide for Satellite Pro 4300 Series (5790)at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107128&moid=1073769765&BV_SessionID=@@@@0579949615.1140817607@@@@&BV_EngineID=cccfaddhdidhgdecgfkceghdgngdgmm.0&ct=DL. Hope this works out ok for you. Regards.
Apr 09, 2007 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Toshiba satellite goes dead
Assuming this is not hibernating and your harddrive is not set to shutdown after a certain idle time, it could be this is an overheating problem. Check that the extraction vents are'nt blocked and that the fan area is well ventillated. If necassary gently hoover around all ventillation slats. Some laptops have the ability for the user to turn off the fan for certain usage, just check in your management settings that it's turned on, unless you know it is on' and it cuts in or stays on.
Jan 10, 2007 | Toshiba Satellite 4300 Notebook
Toshiba Axiom 60GB HDD Satellite Pro 4300, 4280, 4260 Series (AXT0760) Hard Drive Logo
2,230 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
