Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Installing problems I bought the MFC-240c printer and now trying to install it. But it doesn't completely install. It stops from where it asks to plug back all the connections(USB and the main power). It wont load after that. I've tried everything else. Immediate help would be appreciated. Thanks.
  • 3 more comments
  • have no clue Feb 19, 2008
    i just bought a new computer and a printer with fax,copier,scanner,photo capture center,pc,fax and it will not install it will stop when it gets to the window installing and sit there please help me install this
  • Mmpeters Feb 22, 2008
    I am having the same problem. I also can't fax out. How can I fix? Please help. It is new and I don't want to have to take it back.
    Thanks Melissa
  • Anonymous Feb 23, 2008
    i can't install my brother 240c im my computer which have a window vista driver
  • Anonymous Apr 26, 2008
    Yea, get as far as connect usb cable into computer and printer machine then stops. can't load Brother MFC-240C.
  • klav0925 Dec 01, 2008
    mfc 240 - i can not install the user guide on my vista
    Sergeant:
  • 390 Answers
Check your pc for compatability to the unit and its software. Check you have no other old printer settings left on pc (causing conflict) check your pc memory is not causing issues, or your operating system is compatable. Sometimes software and pc's can just be pigheaded and stubborn (i realise they are not human but it sure feels like it sometimes)You need to completely uninstall all traces of the printer drivers before reinstalling. Go to computer, local disk, programs, and see if there is an icon or folder for your program. If so, delete it. Do a search too and type in your printer (make sure disc is not in drive) and delete any settings it finds. Now try reinstalling it again.
Posted on Aug 17, 2007
SOURCE:
I need control center for my brother mfc-240c
You can download that from www.brother-usa.com. Look near the top-right corner for the blue box labeled Service & Support, and click "Downloads." You'll have to select your machine's family (Multi-Function) and model, then your computer's Operating System. For most machines, Brother offers a choice of barebones drivers or the complete package; you'll want the full package to get the Control Center.
Brother requires that you install the driver package before you plug the machine into your computer. If you have already plugged it in and let Windows try to install a generic driver or something, you may need to download and run a utility for uninstalling the machine completely before installing the package properly. That utility program is probably at the bottom of the page of drivers on the Brother site.
Apr 03, 2010 | Brother Multi-Function Center MFC-240C...
Im trying to install my mfc-240c all in one printer to my laptop,I have tryed my install disk,but it still is haveing problem.
what is the problem you are having? be more precise please
For starters most of these things don't like being plugged in before the software is installed so unplug it then go through the software install and plug it in only when it tells you to.
Dec 29, 2009 | Brother Multi-Function Center MFC-240C...
Bought new computer and lost cd installer for Bother printer MFC-240C. How can I install it and make it work?
http://support.brother.com/g/b/downloadtop.aspx?c=as_ot&lang=en&prod=mfc240c_all select your operating system and download your driver. install it and plug in your printer. turn it on. your computer will recognize it and it will install itself. go to your control panel in the devices and printer and make sure it is selected as your default printer.
You're done.
I’m happy to help further over the phone at https://www.6ya.com/expert/troy_d840d2702258460c
Sep 09, 2009 | Brother MFC 240C All-In-One InkJet Printer
Error 52 brother mfc 240c
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Jul 20, 2009 | Brother Multi-Function Center MFC-240C...
Invalid Access to Memory Location
first turn everything off unplug the printer.hook the usb to the computer before you do anything else,then turn on the unit it should make all the adjustments.
Jul 09, 2009 | Brother Multi-Function Center MFC-240C...
How to connect MFC-240C fax/printer to my computer
http://www.nodevice.com/driver/MFC-240C/get41297.html
from this link you have to download th edriver for this device ...
after that if it has a usb cable or a regu;ar printer cable ...conect it to the pc
when its plugged well you will hear a bel sound from the new device found wizard...
ya may also run the driver first ...so in the moment that you plug the printer you already have it into your pc..and the wizard will just complet the installation
Jun 07, 2009 | Brother Multi-Function Center MFC-240C...
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Instructions
first you will have to install the cd that came with the printer. i will assume that you bought the printer new, some where while you are installing the cd it will ask you to plug the usb cable in to the printer. one end into the printer marked usb and the other end into a usb port on the back of your computer. if everything installed correctly, you will be ready to print to the printer. good luck brother tech
Sep 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
77 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
