Question about Mitsubishi VS-60805 60" Rear Projection Television
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
My Mitsubish VS-60805 is connected to a HD DVR cable box and a DVD player. The TV works great with the DVD player (picture is in HD) but with the cable box for television viewing I get a blank blue screen when I try to view HD channels. Non HD channels are fine. I switched cable boxes with one that is attached to another TV in my home (that DOES show HD channels)and is connected the same way the Mitsubishi is) and it still doesn't work. THe HD box output is 1080i but I could only select 480 or 980 on the Mitsubishi setup screen on the TV...... could that be the problem? Help.... I just bought this TV from someone who only used it in straight coax cabl mode (no HD) so they don't know if it ever worked. I had the Mitsubishi TV guy here and he says there is nothing wrong with the TV....supected the cable box was bad. I got a new one and it still doesn't help. Any advise?
  • Anonymous Mar 14, 2014
    how to connect cable box
  • Anonymous Mar 23, 2014
    cable box froze and i unplugged both the tv and the cable box, but it looks like the tv now needs a system setup
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Posted on Aug 25, 2007
SOURCE:
I have a mitubishi ws-55313 with a monitor link DVI connection and I have tried to convert that to hdmi for a cable DVR but it doesn't work any ideas?
The monitor link is not a standard DVI connection, it was used to connect a Mitsubishi HD set top box. You can connect your cable DVR using component video cables and get HD that way, up to 1080i but not 1080p
Apr 15, 2014 | Mitsubishi WD-52525 52" Rear Projection...
I have a 4 year old Mitsubishi WD-57831. Lately, when connected to my cable DVR via a HDMI, the picture flashes on and off and some stations don't come in at all. I changed the cable box 4 times, changed...
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Aug 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Jan 15, 2010 | Mitsubishi VS-60111 60" Rear Projection...
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Scrambled picture mitsubishi VS-60805
Hello deltamech,
Are you using your component video cables? if you are check to see if you are using the correct inputs. Look at the babck of your TV and see if the RGB (Lettering) matches with the box you are connecting to. What I am talking about is the YP(b)P(r) vs the YC(b)C(r) they are incompatable with each other.
Check that and if that is the case either match the two proper RGBs up or use another interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Fullscreen HD?
check to see if the box has a tv type setting in it's menu since I don't know what the model of the HD box is it must be in the user manual on how to set this up. it is not the tv that is the problem.
Jun 06, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Trying to get Fullscreen HD.
MY TV HAS SOUND BUT NO BIG PICTURE IT HAS A LIL PIC IN THE RIGHT HAND CORNER WHEN U PRESS MENU.
I HAVE MODEL NUMBER VS-50603
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
321 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
