as for noise will have to inspect under hood,could be fan or belt or pulley ,water pump .these are some things it could...My suggestion for overheating is replace thermostat. If your car has electric cooling fan then it may not be working..turn defrost on and if fan kicks on then fan motor is good..Now this does not mean that fan is working properly because fan is controlled by heat sensor switch that kicks fan on when motor reaches heat range......Things i would have checked....hope this information helps and good luck and Please rate my post...
Don't you think the Benq company would have thought of that.The general rule is - a fan that makes less noise pumps out less air !!! In other words the noise is related to the speed (rpm) and blade design.Put the wrong fan and you might damage the projector due to overheating .
remove the thermostat and place in a pan of water a boil and wait to see if the thermostat opens , as for the noise , get the thermostat sorted out and see if still makes the noise , could just have been caused by the overheating, one thing at a time so you know what the problem is
just in case it is overheating, blow out any dust with canned air and make sure the fans are working. also, keep anything from blocking the vents. if all that is done and it still shuts down, you have a power supply that needs replacing.
clean it out with canned air. the dust keeps in the heat that the projector is trying to expell. you may need to replace the temp sensor, as the constant heat may have weakened the sensor.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
Hi, I'm not sure if it's the same problem I had.. I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
Review Date Monday, 12th of September, 2005 -->
What's Hot User-friendly, built-in DVD player, high-throw ratio lens, fast power/cool down
What's Not Fan operation is quite audible, native resolution of just 480p
The Final Word A perfect coffee table companion
Notes
# This product is no longer available directly from the manufacturer. It may be
available in retail and distribution channels, or second hand. The price
displayed is the price at review time and the last available recommended retail
price.
The DV10 has a futuristic-looking outer casing and two internal
speakers located behind a silver grille mesh at the rear. Heat is
removed through its side ventilation and the internal fan has a noise
level of 27dB, which is comparable to a loud computer and quite
distracting when watching movies at low volume. At 368 x 117 x 273mm,
the unit is small enough to permanently and inconspicuously reside on a
coffee table.
this is from a review .
it sounds like that the fan needs to be cleaned the sound you hear is normal but if it sounds like its racein the moder might be on its way out if you have a can of air used to clean a key bored i would try to clean it out with that if not take it to a repair place to see if they could look at the moder
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
