Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Spectra Range
I'm using natural gas. It was working fine but now the high speed burner is sooting the burner and the pots and pans occasionally. the flame is nice and blue and when it fails it seems to be uneven and orange. I removed the burner, cleaned and checked the jet and it all looks like new. None of the other burners are causing a problem and the oven is working fine. The fact that it is intermittent has got me baffled. Could the valve cause this problem, I don't know what is left.
  • Ohio John Aug 18, 2007
    There isn't any regulator. I'm surprised that it is so intermittent. It works for several days no problem and then it starts to carbon up. What goes bad in the valve to do this?
    Thanks for your help.
  • 640 Answers
If you have a pressure regulator coming off the main gas line to the unit make sure the vent isnt clogged.its a little nut on top of the regulator,unsrew it and clean it up with w-40.try this and see what happens.if no improvment the gas valve is faulty.
Posted on Aug 17, 2007
  • anthony james
    anthony james Aug 21, 2007
    the seat in the valve gets worn,there may be a kit to rebuild it but its easier to replace the valve.i would agree with reel337 but it wouldnt be intermittent like you said.i belive its the valve.
  • 3 Answers
There is too much air in the mixture, close the air shutter on the burner a little.
SOURCE:
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
How tp clean black soot off bottom of turkey pot
If you are cooking with propane or natural gas, you may need a new regulator for your range, the black soot is most likely too much gas being used to make the flame. But, as for the soot on the bottom of your pans, try letting the pan soak in a mixture of baking soda and water, then attack it with a brillo pad. Hope this helps!
Apr 10, 2012 | Kitchen Ranges
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
SOOT BIULD UP UNDER PANS? WITH MY GE PROFILE XL44 SPECTRA GAS RANGE
Air mix of burners is wrong. Need more air vs fuel.
Should probably get a pro to adjust under warranty.
Feb 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
Gas stove causing soot on everything
all of the burners are set to rich...open the vents on the burners more.  If this doesn't help you need smaller nozzles.
Mar 26, 2009 | Whirlpool Gold GW399LXU Gas Range
Flames are extremely uneven and high
okay, DO NOT USE THIS STOVE ON LP GAS.
It's not intended to be used with LP gas, because LP gas requires a smaller orifice than natural gas. Call your propane supplier IMMEDIATELY...DO NOT USE THIS STOVE UNTIL IT IS CONVERTED TO LP GAS (if it's even possible)...this is extremely dangerous and you could hurt yourself if you continue to use LP gas on a stove that was designed to run on natural gas.
Dec 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Black soot on bottoms of pans
Wellif you uninstalled and reinstalled the same appliance it should work the same.. thats weird that it changed. however the black soot is usually from flames that are to high. you could try tightening down the orifice where the gas comes out.
Dec 01, 2008 | GE Spectra JGBP35 Gas Kitchen Range
Had a new gas hob installed but two of the gas burners only have a very low flame even when turned to high. One of the others has yellow flame tips even on low and is leaving marks on the bottom of the...
propane or natural gas? if it was converted inproperly it will leave soot on your pans. also you will see flames when you bake with it or broil.
Nov 01, 2008 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
199 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
