Question about GE GSS25SGMBS Side by Side Refrigerator
Water in door stopped dispensing
WATER IN THE DOOR HAS SUDDENLY STOPPED DISPENSING. ICE SEEMS TO BE WORKING FINE. THE ICE BIN IS FULL AND WILL DISPENSE. CAN'T GET WATER TO DISPENSE-- I notice this was posted previously and I have the exact same problem. The only thing I can add is that when you press the water dispense button you can hear it hum.
  • 1 more comment
  • cjob Aug 18, 2007
    After reading all the other threads I decided to see if it was just frozen up. I opened the door, turned off the freezer, put a blow dryer in the ice chute and let it run for about 5-10 minutes. Worked like a charm!
    This board is a lifesaver.
  • Anonymous Mar 23, 2014
    The ice bin doesn't turn all the way around it turns a little bit then turns back and there is ice in the bin
  • Anonymous Mar 30, 2014
    No water from door dispenser
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Posted on Aug 17, 2007
SOURCE:
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Lg freezer ice maker making ice but not dispensing
I have the same problem. I am getting tired of having to clear it out about once a week. I take the ice holder out and empty it in a large bowl and remove any large, melted together pieces, then replace it. It works fine for a while.
Mar 17, 2017 | LG LSC23924ST Refrigeration : Refrigerator...
Whirlpool refrigerator won't make ice--just out of warranty
I would have to say control board but you could look for a bin level switch. This is what tells the machine that the ice Bin is full. If it is duty or damaged the machine will never make ice as it thinks there is enough already there
Sep 05, 2012 | Whirlpool Refrigerators
I have a Whirlpool White Conquest Side-By-Side Refrigerator GS6SHAXLQ03, manufactured March 2003. The ice maker creates ice and fills the "holding bin" on the interior of the door. However,...
The ice will melt during the defrost cycle. Make sure your freezer is cold enough, at least -5, preferably -10. also, if your freezer is not full of food, put some milk jugs full of water in there to take up space. This will keep the temp colder when the compressor shuts off for the defrost cycle. if there is too much empty space, there is not enough mass to stabilize the temperature and keep it cold.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water dispense in the door of my fridge stopped working. I checked the lines in back and took the filter out to check it. All seems fine. As far as I know it's making ice because the bin is full.
Check the line under the door, there is a connection you can release and check if the water is flowing through the filter etc. My guess is the water line in the frezzer door is frozen. I thawed it out with a hair dryer and a wire snake but it froze again. Don't know the long term solution.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
WATER IN DOOR
bad solenoid assembly maybe
Jul 05, 2007 | GE GSS25SGMBS Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
416 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
