Question about KitchenAid KESC300 Electric Kitchen Range
Oven is not working
We have a Kitchenaid kesc300 oven. For some reason the oven stopped working today. I am bummed because the oven is probaby only around 2 years old. The display seems to be working ok, but the oven does not heat up at all. I tried the broiler too, but it also seems to be broken. I thought that it might be an element, but I doubt that both went bad at the same time. any thoughts? I appreciate any help you can give.
  • rcminga Jan 28, 2009
    Fridaire range was in use when oven element stopped working, then checked broiler was checked, but it does not work either. All the eyes work.
I had a similar problem while mine was still under warranty. Seemed like every time I used the oven and stove top for a major dinner it would short out and I would get an error code: F1:E6. They replaced the board under the display area, but it happened again about 6 months later. Turned out that when they made the oven they didn't insert a chimney like vent system from the bottom left side of the oven to the vent holes that come out the upper left side of the stovetop. This caused the panel to overheat and stop the entire oven from working. They replaced the board again and installed the "chimney vent system" and I haven't had the problem occur again (it's been 3 years!).
Posted on Feb 17, 2008
    Scholar:
  • 196 Answers
Both elements are controlled by a common relay on the ERC (Electronic Control Card) and cannot be repaired. The ERC needs replaced. This is also referred to as the Clock/Display.
Posted on Dec 30, 2007
Kitchenaid electric range model kesc300, why does oven go on by itself and i cant shut it off unless i closs circuit breaker
Ghosts....
Okay, at this point some trouble shooting is needed. Unless you have a multi-meter and know how to use it you need a professional. Surges in thesource may cause this as well as poor grounds in the builings electrical sysytem.
Oct 09, 2014 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
I tried to change the light bulb in the oven, thought I had the power turned off, I did not. The bulb socket sparked, nothing seemed to happen but now my controls on top of my kitchen aid KESC300 electric...
Hello- Glass bulbs don't make very good handles, do they? Find a good tech to check wiring behind bulb socket. May have burned a connection, and or grounded a wire somewhere. Electric ranges have two 110v circuits that work in combination. One is out. Let me know if info helps- have more if needed- Thanks- ED
Mar 04, 2010 | KitchenAid KESC300 Electric Kitchen Range
Burners are working oven is not working ?
The heating element may be burnt out, you will need to replace this element if it does not heat up when the oven is turned on, try turning the oven to broil if the top element heat up then indeed it is the bottom element and need replacing.
Dec 18, 2009 | KitchenAid KESC300 Electric Kitchen Range
Oven unit not heating up - Kitchenaid KEMX377GWHO
This sounds like a blown thermal fuse, a common problem. What model oven was this?
Dec 02, 2008 | KitchenAid Architect® KEMS378S Electric...
Error code F1E2
The code F1E2 refers to a watchdog circuit in the ERC (Electronic Control Card). This can only be corrected by replacement.
Dec 29, 2007 | KitchenAid KESC300 Electric Kitchen Range
Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Sep 30, 2007 | KitchenAid KESC300 Electric Kitchen Range
Oven not working
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean 2. Test relay contact operation 3. High resistance in oven temperature sensor
Sep 05, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
316 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
