Question about DeLonghi DBM8150 Work Top Blender
DeLonghi DBM8150 problem
I bought this from costco and used it 3 times. then it stopped working all of the sudden. now cosco don't carry it any more so how can i fix this?
These instructions disassemble an electrical appliance. You should have some technical/mechanical/electrical experience to attempt this and you do so at your own risk.
See exploded diagram : http://www.kenwoodservice.co.uk/uk-delonghi/exploded/exploded-KF8150M.pdf
This is not a very good diagram to show the disassembly, however, it will at least help me to identify the parts.
Prise out the center insert in the drive wheel (#15 on the diagram) on the top of the base unit (I used a paring knife and worked my way around the circumference to work it loose).
Remove the four rubber feet (#19) from the base by pulling them out.
Undo the 4 phillips head screws in the holes where the feet were.
Remove the base and carefully position it along-side the body of the blender.
Prise off the silver switch knob (#13) - it slides straight off the switch shaft and I used a screw driver to carefully lever it off, working from each side a little at a time.
Undo the drive wheel on the top of the drive shaft by holding the fan on the bottom of the drive shaft and turning the drive wheel CLOCKWISE.
Undo and remove the two screws holding the switch support (#11) and cut the tie wrap that secures the blue cable to this support.
Undo the four screws that secure the motor assembly to the casing and remove the screws and their shake-proof washers.
Remove the internal components as a single assembly. Tilt/angle the motor assembly towards the switch support until the top of the shaft clears the rubber boot in the top and then the whole lot comes out easily.
To replace the switch (Part No. HS1144 - #10 on the diagram):
Carefully lever the white gear wheel off the switch shaft.
Undo the two small screws that hold the dial gear wheel cover in place on the switch support.
Remove the cover and the small gear wheel (noting which way around the gear wheel goes the two ends of the shaft are slightly different).
Undo the nut on the switch shaft that that secures the switch to the support (nut is 14mm diameter and needs a thin wall socket. I used long nose pliers to remove and re-install it).
The wires connect by simple push fit into their slots and the angled brass blades inside the slots grab the wire and lock it in place. To withdraw each wire, use a very thin screw driver (or similar) to depress the brass blades inside the slot. This enables the wire to be withdrawn as you depress the blade.
Re-assembly is the opposite sequence.
When putting the dial back together, remember to check that the dial reading lines up with the switch position (adjust the gears by resetting the teeth if the alignment is not correct.
Here’s the really interesting thing. After I replaced the switch, I pulled the old one apart. IT HAD FAILED BECAUSE THE CONTACTS HAD BURNT OUT. They had obviously been arcing and had completely burnt through. There were burnt off tails of the contacts lying in the switch housing and there was evidence of burning (carbon deposits) inside the switch. In short – the switch is not up to the job and will fail. Poor design and a latent defect.
Posted on May 30, 2009
I need to reemplar the elices of the mixer since two of the 4 spears of the mixer became broken to me
Posted on Feb 25, 2008
My Blender is not working.I can presume that it's motor have som problem...In this morning I used this blender and suddenly stopped to work....
not sure what that could be,if you have no power at all,i would first check and make sure the fuse is ok.
or try plugging it in another outlet to to make sure its not the outlet thats faulty.
Oct 26, 2017 | Brentwood Blenders
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
Vitamix 5000 suddenly stopped working
As the override gizmo will not reset when cooled down you do know that it is faulty so replacing it is going to have to happen anyway if you are repairing it. It may be just that item that's gone bad or it may have been made bad by the motor drawing excessive current. The proper way to check current draw would be by running it through an ammeter. The last thing you want is a faulty motor, they cost a fortune.
Dec 19, 2017 | Vitamix Super 5000 Work Top Blender
BLENDTEC BLENDER WONT WORK WATCH DOG TIME OUT?
That is a motor issue, you need to contact Blendtec customer service. They will let you know if it is still under warranty. 1-800253-6383.
Oct 31, 2009 | Blendtec HP-611-FLP / HP-621-FLP Work Top...
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
Jun 23, 2009 | Kenmore 204101 Single-Speed Blender
Handle came loose on DeLonghi DBM8150
Took Handle apart and reglued broken pieces.
Jun 01, 2009 | DeLonghi DBM8150 Work Top Blender
REPLACEMENT GLASS JUG FOR KF 1850M DELONGHI BLENDER
I want to replace plastic jug of my blender, It leaks
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
DeLonghi DBM8150 Work Top Blender Logo
315 people viewed this question
Top DeLonghi Blenders Experts
eyecam
Marvin
Marvin
Are you a DeLonghi Blender Expert? Answer questions, earn points and help others
