Question about Vivitar 2800 Flash
2800 Flash Unit will not turn on. New batteries have been installed.
  • 1 more comment
  • Anonymous May 11, 2008
    Put new batteries in my vivitar avto thyrirtor-2800-d
    put batteries in right position but does not work
  • Daisybor Aug 16, 2008
    I put in four new AA batteries, and the unit would not turn on. It had been sitting in a closet for years prior to this happening. I was working fine the last time I used it. I made sure all contacts were clean of any dirt or obstructions, but unit will still not turn on.
  • clobreau Jan 23, 2009
    vivitar auto thyristor 2800-d, noo flash new batteries.
    Champion:
    Scholar:
  • 216 Answers
Put 4 batteries in the right directions?
atdlee@netzero.com
Posted on Jan 03, 2008
CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Sep 04, 2009 | Ctm HS-2800 Power Wheelchair
Reset the drum count on a brother intellifax 2800.
Drum counter is reset by installing a new drum which contains a specifically designed "starter sheet" that is passed through the machine when it is installed, and triggers the paper sensors in a specific pattern, resetting the electronic counter.
If you have installed a new drum and the message remains......I suspect that it was a remanufactured unit that did not include the "starter sheet" Is that the case?
May 03, 2009 | Brother IntelliFAX 2800 Laser Fax
Using a vivitar 2800 flash on a nikon d60
The old series Vivitar 2800 flashgun has a very high trigger Voltage, that can damage your D60's circuitry. Even measuring the trigger voltage with a voltmeter is not a solution since you can't rely on the voltmeter to indicate the peak voltage.
Feb 05, 2009 | Vivitar 2800 Flash
Vivitar 2800
1 Does it give the normal little charge up whine when you turn it on?
2 Are the battery terminals clean?
3. Double check with new out of the packet top quality Duracel or Energiser batteries. Don't waste your time testing anything like this with mediocre or average batteries.
4. If you have to ask if you could fit new capacitors yourself, the answer is DEFINITELY NOT. These caps are not like on a computer motherboard: These can stop your heart.
5 Some of the big camera shops can give you a free repair quote, or if not will deduct the cost of a declined quote from the price of a new flash.
Anyway, good luck.
Jul 13, 2008 | Vivitar 2800 Flash
I'd like to know if I can use a Vivitar 2800 flash in a Nikon D80 safely. I've been using it, without any problem, but read that maybe this flash can be dangerous to the D80 and I want to be sure. Thanks.
Yeah Rolo, I read that too. I would put a slave unit on your Vivitar, and the Master would be the pop up unit on the camera. Not only will you save risking your camera with the voltage of the flash, but your pictures will be better too. I use Aperture Priority on the camera and AUTO on the Vivitar set to the same aperture
Best regards,
John
Jun 25, 2008 | Vivitar 2800 Flash
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
My unit has power, but it won't turn on at all.
This means that something is seriously wrong with the unit(blown amp, shorts, opens, etc.) however, you can reset the unit by unplugging the unit, holding the A and B channel buttons on the face of the unit and plugging in the reciever. the display should flash at 1 second intervals. if it doesn't stop flashing on its own then unplug and replug and you should be good to go! good luck.
Jul 31, 2007 | Denon AVR-2800 Receiver
2800 with the new sony H9
hi, i too own a sony dsc h9. sony h9 does not have a hot shoe and how did you connect both the camera and the flash. you can use a slave unit with hot shoe to which you can connect your flash unit. now disable your red eye reduction in your sony and click the shot both the popup flash and the vivitar will work fine
Jul 21, 2007 | Vivitar 2800 Flash
Vivitar 2800 Flash Logo
142 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
