Question about Kenmore 82822 Electric Dryer
No nothing! -Kenmore HE3 DRYER # 82826
Bought this dryer as a set from what seemed to be a really nice couple who were upgrading.Hauled it all home and the washer worked great, but when I plugged the dryer in--nothing. No lights, no beeps, no display, no light when you open the door. I was suspicious of my outlet, of course at first, (this house is a remodel and I have never tested the plug) but the Ohm meter reads 240. I pulled the front of the unit off and the thermal fuse on the back of the blower assembly showed current running through. I was heading for the top of the unit next, to see if there might be any other fuses, and the I struck GOLD! Inside the dryer in a little plastic bag was the service guide! I followed the step by step instructions to test the dyer cord-- hot and ground against the main computer board (P1-5 and P1-2) and both flowed (beep!) through the ohm meter. With this diagnostic, the guide says "replace the machine electrical control." $124 bucks. Ugh. So here are my questions: 1) is there anything else I can test to make sure it is this board that needs replaced? 2) Anything else that might be killing the whole electric workings of this dryer? 3) How can I test the control logic board to see if it needs replacing too? Thanks ever so much for your help! -Jessie-fix-it
  • fix-it-gal Aug 18, 2007
    Great! Thanks, this helps a bunch. Appreciate your time :-)
  • 5,911 Answers
Unfortunately, the Main Control Board generally is the culprit that kills the entire dryer on these models. The tech sheet you discovered should also give you the test points to check the control panel too. However, if the Main Control Board is bad, it will do you no good to try to trace voltage if it's not there. In addition, the connector pins are so small it makes it rather difficult to even try to get good resistance readings. Now...to rule out other possibilities: THERMAL FUSE - Would kill all dryer functions, but I believe the control panel would still work and the interior drum light would come on. THERMAL CUT-OUT - Would only kill the HEATING portion of the dryer. The drum would still rotate, but the unit would not heat. DOOR SWITCH - Control panel would still function, but dryer would not start and drum would not rotate. BELT SWITCH - This will shut down a dryer if yours is equipped with one. I don't believe this model has such a switch, but even if it did, the dryer would not start, but the control panel would still light up. So...other than double checking all your wiring to make sure you don't have anything broken or loose, you have probably narrowed it down to the most likely cause. You still might have a defective interface panel, but they don't fail as often and are more expensive. Generally, the whole panel has to be replaced. I hope this guides you in the right direction. If you need further assistance, post comments.
Posted on Aug 18, 2007
  • 24 Answers
PS: The HE3 does have a belt switch right near the motor..
Try the hir-dryer trick on the main buttons.. or of you can solder replace all of the buttons on the main control panel. they love to stick ON and cause the entire thing to appear dead (see my other post on the dryer fix) other items were also listed.. check the little white fuse just behind the lint-vent (under lower cover, behind the galvanized vent that covers the fan (left sensor)) that one and the door switch (blue/white) kill the motor completely.. ohms-beep them for good connections..
Posted on May 19, 2008
SOURCE:
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
Everything works on panel but when you push start it clicks and nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Hi,I have a Kenmore Elite HE3 electric dryer which is only about 3 months and the problem is that when I press the power button, nothing happens, even though the dryer IS connected to electricity beacause...
heatman101
Oct 20, 2010 | Kenmore 82822 Electric Dryer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 is not turning on. the timer is working correctly, but when you press the start button it sounds like an overload trips
heatman101
6ter
Jul 11, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 82822 Electric Dryer Logo
1,088 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
