Question about Maytag Neptune MAH6700A Front Load Washer
Maytag MAH6700A Washer will go thru cycles properly only when empty. With clothes in it will fill, wash and drain, but not spin.
    President:
  • 331 Answers
Dough, these models have had issues with the wiring harness that connects to the motor. UNPLUG THE MACHINE!! Pull the unit from the wall and remove the rear panel, 4 screws back there. On the rear of the tub about the 5 o'clock position, you'll see the motor. See the wires that connect to it? Check to make sure they are properly seated in the connector and that the connector is properly, firmly seated to the motor. Then replace the panel, push it back to the wall and plug it in. Now, for the diagnostics mode and "quick spin test". Press "chime" and "extra rinse" buttons at the same time for 3 seconds or until unit beeps. This will put it in Service Mode. Now press both the "delay start" and "rinse and spin" keys at the same time. The unit should initiate a spin test which will ramp up to maximum speed and hold that speed for 2 minutes, then ramp back down. Exit Service Mode the same way you entered it, above. After doing these tests and checks, post back and let us know what happened.
Posted on Aug 17, 2007
    Novelist:
  • 159 Answers
Have you checked the belt to make sure its not worn and loose? that would be the first thing I would check
SOURCE:
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Fills but does not wash
Hi!
That happens when for some reason any of the two drain/spin cycles are interrupted. Try this:
have the washer empty, then set the machine to run the last cycle to the end of it, when you usually
lift the cover to take out the clothes, that ought to do it, I had the same problem when diagnosing a
timer problem.
Nov 09, 2008 | Maytag Performa PAV2200
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
Maytag neptune tl washer
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
Apr 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
