Question about Harman Kardon Creature II Computer Speakers
Compatible? I now have a third set of speakers. I returned the first two. I believe it's not the speakers thats the problem, I think it's the tv that im trying to hook them up to. the speakers work, its the volume control that doen't always work, I have found no pattern to this problem. it seams the volume works when it wants to. my tv: insigna, 20" tv/dvd combo IS-TVDVD20 I have tryed everything I can think of, I have been very patient, and precise on how I set everything up.
    Problem Solver:
  • 8 Answers
Have you tried sending out the signal from a TV to an amplifier then to the speakers? Can you give me a specific set-up on everything you are using, including cables?
Posted on Aug 21, 2007
Internal speakers won't turn off when external audio is connected
Normally , you would expect the TV sound to stop when headphones are plugged in. Obviously not in this case. If you have a set of headphones, try them and see if the TV still has speakers on. If it does, then there may be a setting on the setup of the TV to get headphones to work. If the TV speakers stop, then I would think that the Logitech are not compatible with the TV. The only other thing would be is to get into the TV and disconnect the TV,s own speakers. If the wires are soldered on and not terminal connected, carefully cut 1 of the wires off near the speaker. If 1 wire is cut, the speaker wont work. Make sure both the TV and the additional speakers (If they have their own power supply) you are using are unplugged from the power before you go doing this...!
May 26, 2015 | Haier L32F1120 32-Inch LCD TV 720p 32"
Magnavox LCD tv external speaker
Hello
The jack you describes here "Digital Ouput Device To" means, you can connect these jacks to the output of a digital device, such as DVD or so. It is meant for to get signal into the TV, not ot out.
HDMI [High Definition Multimedia Interface] is a type of connection, which the TV an be connected to any HDMI device from outside. Both the above said are, signal in to TV connections. Not out.
If you want to connect this TV to any amp or any other external audio devices; look for any audio out option is there.
Feb 05, 2012 | Televison & Video
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
How can I mute the headphone jack on an Insignia 22" lcd TV? The remote control will mute the internal speakers but not anything plugged into the phone/headphone jack. Must I open up the TV and make an...
As an idea, I was thinking as I read your post, I thought that this would be an ideal application for a pair of "Wireless/Ired Headphones", you could plug these into the headphone socket, and then use these to hear your sounds, these units have a mute on board.
You could indeed wire it into, the unit going in through, the back of the, set. You could wire it up, but in reality, it would be better to use a third party device and that way would not compromise any warranty.
Jun 11, 2010 | Televison & Video
Keep blowing out bass on speakers Denon 75rd
Thank you for responding. I called in an audio specialist to look at the whole system--he believes there is a problem with the amplifier. Will post what he finds out when he looks inside.
May 01, 2009 | Denon DRA-375RD Receiver
I have the logitech mm50 portable speakers; the on/off button is flashing red and the 3D-sound button is flashing amber; the battery is fully charged; it's been like thise for days; i've tried holidng all,...
Here's what is going on - the mm50 speakers were made in 2005, before iPod decided to release third generation, fourth generation, and fifth generation players. The product specs for the mm50 might have said it was compatible with an "iPod classic" or an iPod "Nano" - but they were referring to an earlier generation of player. These Logitech speakers/dock just isn't compatible with 2006-2008 iPods.
Reset the ipod and run the Recovery Tool like the user manual suggests - the full manual is available at Apple's website.
If it is still possible, return the Logitech speakers.
Jul 06, 2008 | Audio Players & Recorders
Hd compatible?
The instructions for your TV set should answer that! From what I remember, I believe your set is not HD compatable. I am guessing from memory with this.
Jerry G.
May 24, 2008 | Philips Magnavox 27MS343S 27" TV
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Adding a audio jack to KV-32S42 sony TV
yes, just tap in at one of the speakers. The jack should have an internal switch so that the internal speaker is hooked up when the headphones are not in. Most TVs are now stereo (even though analog broadcast signals are mono) so may want to get a stereo jack and tie in from both speakers.
Jan 10, 2008 | Sony KV-32S42 32" TV
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Harman Kardon Creature II Computer Speakers Logo
59 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
