Question about Sony KV-35V68 35" TV
Pink and jumpy
The color on my tv is pink! Also, it jumps between regular tv and video 1. I almost ruptured my spleen getting this big sucker in place for my viewing pleasure those many years ago. I don't look forward to moving it to make room for a new tv, so any help would be great. And yes, it took 3 adults and dog-gone near a fist fight to get this tv in the house...can i get a whut-whut! ha, ha
  • 3,130 Answers
Re: Pink and jumpy
The reason the picture is pink is most likely the picture tube, and that's what weighs so freaking much,is going out on this set. The specs on the tube have changed, but all may not be lost. The set maybe able to be adjusted, but this is a thing that only a trained service tech should attempt. This will involve going into the service menu and realigning the RGB drives and RGB cutoffs for the tube. If the tube is really bad, the alignment will not work. If you wanted to attempt this alignment yourself, make sure you have the service manual and understand the full procedure before you start, as once you start your be committed to the alignment. This set is worth at least a service call as if the tech can adjust the set, you should get some extras time out of it. Good Luck
Posted on Aug 18, 2007
0 characters
3 Points
Got it new at Walmart in 2006? Never had any problems with it, and always had a surge protector. I know the kids have abused it though. Anyway, yesterday they had a pink, washed screen, turned it off/on...
No.The tv video board have dead components,that the board where it is connected to the CRT-(tv picture tube).Troubleshooting that video board and changes parts should fix ur tv problems.Hope ur tv problems,it is not the video board main big IC colors processor inverter.This big IC is a pain to change and probally not in the market anymore.Troubleshoot test all the capacitors around that big IC colors processor inverter alot of times just those few capacitors are dead only.
Apr 02, 2011 | Sanyo HT30744 TV
The tv screen has gone pink. no other clor, just pink.
Tv have 3 colors guns like R,G,B colors.Tv is missing one of it color gun.Have a soldering iron and a roll of solders? Take the tv aparts,resolders the video board soket pins holes that connected to the CRT-(tv tube).Resolder the Yoke wires like R,G,B connected to the main board too.Will solved this problems.
Mar 16, 2011 | Curtis-Mathis CM32010 TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen me what happened. GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Pink Picture
You TV missing Green color ratio to produce correct colors in picture. It might needs service and adjustments in Video section .
Aug 03, 2008 | Sony KP-53HS10 TV
Pink tint problem with a sharp T.V
Go to TV Menu and check Color System. Change it to NTSC and Tint option will be enabled. Your TV is now working on PAL color system.
Jul 27, 2008 | Sharp Standard (CRT) Televisions
Color valve pic is pink
The back ground of tv is green,so i might guss the problem is mono chromo ic.what do u tell me about color?
May 13, 2008 | Standard (CRT) Televisions
Wierd Pink colour in corners when on AV
Do you have any speaker alround? Or something with magnet material, on the top?, if yes, move out . If not.......... I recommended this, But!! be carefull!! I dont responsability for incorrect damage ok?. With a speaker or magnet , pass alround area on bad color, just pass quickly from the bottom to top.....Be carefull!!, don't do this on other area, will make big shadows and bad picture... If still there, maybe tv need work on degaussing area.
May 11, 2008 | Pro Line 2089VYD TV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Problems with the picture on my tv. Pink lines across its screen
take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Oct 15, 2006 | Sony KV-32FX20U 32" TV
Sony KV-35V68 35" TV Logo
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
