Question about Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit di260 hi door catch has broken got new one need to know where the screws are hidden to undo this to replace it thanks
    New Friend:
Indeset DI620 appears not to be pumping water in, light 1 flashes as error code is it the motor?
Posted on Dec 30, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
If its the latch tongue remove the top panel...if its the door remove the console
Posted on Jan 03, 2008
SOURCE:
Indesit DG6100W dishwasher will not work
It sounds as though the micro-switch inside the lock mechanism is displaced.
Undo the 6 screws at the top of the door (on the inside) and remove the outer pane. This will give you access to the lock mechanism. Please switch it off first.
The micro-switch can then be adjusted so that when the handle is released, the switch engages (you should hear a very soft click).
Hope this helps.
Jun 20, 2009 | Dishwashers
How to cahnge door lock/catch
check out this site - repairclinic dot com - they have mouse over points to help you repair your appliance
Aug 17, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Dec 02, 2008 | Indesit WA 125 Front Load Washer
We have just bought a new door seal for a indesit washing machine please advise how to fit.
Hi to replace the seal take off the metal ring with a small screwdriver at the spring on the front of the machine than take off the seal then take the top off the machine and locate the screw on the metal ring undo a bit then take off seal replace and put back the new seal in reverse order as I have written
Jul 18, 2008 | Indesit Washing Machines
Washing machine door lock
undo clamp holding door gasket on cabinet and peel gasket back in the area of the door catch.
door lock is just held in by 2 screws from the outside and will come away when these are undone. on some models, there is also a small diameter pipe going to the door lock and take this off. note where wires go before removing them
Jun 25, 2008 | Hotpoint First Edition FEW12 Front Load...
Door catch not sprung back
should be able to flick it out with a screw driver...sounds like part of the catch is broken
Oct 03, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Door catch plate Indesit d61
undo the screws at the top of the front door and puul the control unit out this gives you acsess to the door catch which is quite simple to replace be careful the stainless steel is quite sharpe
Dec 03, 2006 | Indesit 24 in. D61 Free-standing...
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
510 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
