I have Hp color laserjet 2600n -when i print a color document, the left hand side of the page is faded, the middle and right hand side of the document prints fine. Internal documents print perfectly- this problem only occurs when I print a document from my iMac. Apple technicians tell me this is a printer problem. how do i solve it? I am very new to a Mac, so i would basically need to be handheld through the process.
-   I have the same problem with the left side being very faded. I checked the "Supplies Status Page" and all the colors except for the Magenta are printing correctly. The magenta color bar is faded on the left side. I changed to a new cartridge but the status page still shows the fading problem. This laser printer is too pricey to be having these issues. At about $85 a pop for a cartridge I already feel like I've been ripped off!
-   fabgirl
Mar 30, 2009
-   Also having the same problem with a hp1600.
Using the printer on a windows os. Toners have been replaced but same problem also... -   Guest
Mar 27, 2009
-   I have the same problem and I use a PC. I originally had a the 1600 and had the same issue. I took it for repair and it apparently did not repeat for them, but lo and behold it still had the problem. Started using the 2600n and now have the same issue. Did you happen to get any feedback about it from anyone or anywhere?
-   allocc
According to HP if the problem is only when you print from your PC or Mac then you need to reinstall the printer driver. If the problem is also when you print just from the printer, i.e. scanning or test page, then the problem is with the printer.
We've solved our problem with the fading red tones. It's dust build up on the mirrors and lenses. Very, very, touchy area! The entire machine needs to be taken apart and those areas cleaned. We did that and it worked like a new machine, but, WOW, quite the process. You need lots of patience! I found the info on how to take the machine apart on a website by Don Thompson's Service Seminars.
I don't have the website anymore, but you should be able to locate it with his name. It's labled FADING RED TONES ON COLOR LASERJET 2600s. Good luck
i think like Mac technicians, the problem are in your printer, you need remove from the printer the laser/scanner assy, and clean mirrors and lenses, reasembly and try.
I have a 2600 color laser printer. I just cleaned the laser scanner but the magenta is still jumping...
(More)
I have a 2600 color laser printer. I just cleaned the laser scanner but the magenta is still jumping over the page. Any help
When I print documents I get a shadow print on the left side of the page about every 3 inches for a...
(More)
When I print documents I get a shadow print on the left side of the page about every 3 inches for a couple of pages and then it quits
HP2600n attention light and power light blink together at startup. Also printer does not appear in...
(More)
HP2600n attention light and power light blink together at startup. Also printer does not appear in Windows Device Manager. Eventually will enter power save mode and do nothing. I am able to scroll through display on printer, however it will not print test page, reset defaults, etc.. Have uninstalled and tried swapping the USB port & cable with no sucess. I do get a "ding" when pulling the USB from the PC and same when I reconnect, but will not show in Device Manager. What does it mean when both attention and power are blinking together?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
