Question about Mitel Superset 4025 Corded Phone (mitsup4025)
Super set 4025 wont work
My phone says waiting for sync. how do i make work ??
  • 1 more comment
  • Thumper69x69 Dec 18, 2007
    Having the same issues. Purchased 4025 phone at yard sale for home use and getting "waiting for sync" on display panel
  • qilaijun Sep 30, 2008
    can someone help?
    How to make this phone work...all it shows" waiting for sync"
  • Anonymous Feb 20, 2009
    waiting for sync ???
    it's must using pabx mitel maybe >?>??
There are a couple of possiblities - the phone is ported but not programmed, the phone type is not correct (420 instead of 4025) or the wires are reversed.
Posted on Sep 18, 2007
    Problem Solver:
  • 6 Answers
1) The phone cannot communicate with the switch. 2) Make sure your connections are good at both the jack that you plug the phone into and the block or connection coming from the Mitel switch. What Mitel Switch do you have?
Posted on Aug 19, 2007
SOURCE:
How do I change the date and time on a Mitel Superset 4025 phone system?
The time has to be changed in the programming interface of the phone system itself. You cannot change the time from any set other than a 4150 or a super console 1000. These sets can only be used to change the time on a mitel sx200 or icp. This does not work on the 3300.
Oct 09, 2014 | Mitel Superset 4025 Corded Phone...
My corded super set 4025 is flashing all lights and says " BOOT 9.3 MAIN 9.4 (c) MITEL 1999. what do I do ?
Your phone has lost communications with the main controller (back room equipment) and is trying to reestablish the communications link and boot up. Try unplugging the phone (line cord) and then plugging it back in. If that doesn't fix it then either the phone is defective or the circuit going from your desk back to the phone equipment room is bad, or the phone has been deprogrammed from the system database. Hope this helps.
Aug 02, 2014 | Mitel Superset 4025 Corded Phone...
I have a Mitel Superset 4025. The "message" button was somehow reprogrammed so that pushing it now calls the operator, I can access my VM using "8" but the message waiting light is...
it's because the operator set a message to your phone. You need to leave the handset on the cradle and push the message button. Read the display and follow the prompts. You should be able to clear the message.
Apr 27, 2011 | Mitel Superset 4025 Corded Phone...
Waiting to sync message , Mitel 4025
the port that the phone is connected to isn't working properly. Contact your system administrator or vendor.
Nov 15, 2010 | Mitel Superset 4025 Corded Phone...
I bought several used mitel superset 4025 phones. When I try to plug them in (we have two phone lines in one jack), the display flashes "waiting for sync" and the lights on the phone flash (in succession...
the Superset 4025 is a digital set that is intended to work with a Mitel telephone system. The port must be programmed and connected to a jack to allow the phone to work. The phone is not intended to be used as a home telephone.
Aug 18, 2010 | Mitel Superset 4025 Corded Phone...
I was given a Mitel superset 4025, can this phone be used in my home office? When I plugged it in it blinks and says waiting for sync, does this mean I must reset it? if so, how?
This phones is to be used with a mitel phone system .It is a digital phones witch needs to be connected to mitel digital card on a mitel phone system.
Oct 07, 2009 | Mitel Superset 4025 Corded Phone...
I have a 4025 Not Forwarding to VM?
The Call Forward is set up by using the BLUE Super KEY located below the display. You have to know the Voicemail Pilot Number to be able to complete the programming. Basically you press " superkey ", say NO to the prompts until Call Forwarding comes up, say YES to Call Fordward, choise the type of forward you want ( always, no answer, busy, busy/no answer )dial in the voicemail pilot number, press save and then press the superkey to exit programming. Good Luck
Aug 01, 2008 | Mitel Superset 4025 Corded Phone...
Model 4025
In the days before voicemail, Mitel had a "Call Me Back" feature that would light the MWI. We now use the MWI for voicemail, but the capability is still there. You can solve it several ways.
1. Go to the blinking phone and press the Messages button. One of those should be "Call me back". Press it and when the other party picks up, the MWI should turn off.
-or-
2. Look up the FAC for Message Waiting - Deactivate in your phone switch. On my switch it is *91.
Feb 13, 2008 | Mitel Superset 4025 Corded Phone...
4025 wont work....
You cannot change models like that without changing the configuration for that extension in the phone switch. If it's configured as a SS4015, then you can plug any other SS4015 into the jack. If you want to change it to a SS4025, then you need to reconfigure the extension in the switch.
Feb 11, 2008 | Mitel Superset 4025 Corded Phone...
Mitel Superset 4025 Corded Phone (mitsup4025) Logo
983 people viewed this question
Top Mitel Lands Phones Experts
Dustin
Dustin
pawnpower
Marvin
Marvin
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
