Question about Coby 5.1 Channel DVD Player with Home Theater Speaker System System
Sound YOU CAN HEAR THE BACKGROUND SOUND BUT NOT THE PPL TALKING...IS SOMETHING NOT CORRECTLY WIRED??...HELP..PLZ..THANKS
  • 1 more comment
  • trashcan555 Jun 10, 2008
    Same problem music and background sound but no voices
  • Anonymous Dec 19, 2008
    can you help me with the sound problem. music and background sounds ok but the voice is not audible. Polar express dvd. hear thesongs and train sounds but not the voices of the people
  • charliemax Jan 10, 2009
    coby 5.1 channel home theater system playes dvd playes background but no voices whats wrong.
Same here. will never buy a coby again.... store wont even take it back.
Posted on Jul 27, 2008
SOURCE:
I can make calls and receive call and ppl can hear me but i cant hear them on my sharp fx plus
Sometimes network problems make this,
other wise phones speakr problam.
Jan 25, 2013 | Sharp FX Plus
Dvd player spoken dialog volume becomes difficult to hear over background sound
Some sets have a setting called "hall" which if engaged the background noise will be louder than people close up talking, I do not know what TV you are using but look at its options for audio and Hall etc first, its possible the player may have that or something like that also in its menu---by the way, have you confirmed this player has this issue on another set?
Dec 05, 2012 | Televison & Video
My Turtle Beach Headset P11's are brand new, everything is plugged in correctly, as I can hear my friends talking when in a party together, however when I talk they can barely hear me if they can even...
Double check that you are all in the same party. If you are not in the party and they are you will sound very quiet to them. It almost sounds like you are in the background. So go and make sure you can join the party. If that does not solve it go into your settings and double check that mic volumes and everything are all up.
May 26, 2011 | Video Game Consoles & Games
Philips 47" lcd tv #060958514738, it is less than
what you need to do is go into the equliser and adjust the settings till you are happy with it this is the only way to do it i would also maybe advise a surround sound system for around 70 dollars as you said your picture is great you may as well get surround sound to go with your home cinema experience the problem is it depends on ur hearing you may be able to adjust the equliser this would solve anyones problem but with some people their hearing is a bit more selective the tiny little speakers used in these systems make annoying background noisethe only thing i could advise is a surround sound sytem if you still notice it when you adjust the equliser but trust me it is not ur tv it is how good ur hearing is i hate a tv with tiny speakers
Feb 25, 2011 | Philips Televison & Video
Mic isnt picking up voice
IF U ARE USING ANY SOFTWARE TRY CHANGING OR USING DIFFERENT SOFTWARE.ALSO CHECK UR MIC AND CONNECTIONS IS IT WORKING CORRECTLY OR NOT.
Apr 01, 2009 | HP (153147-001) Sound Card
I have vista and im trying to run Teamspeak the program starts and runs fine but when i press push to talk there is no sound also i have turned off UAC so dont need admin rights to run program any ideas
check its setup right for your sound card and the push to talk is set to the button you want, ive had this problem and it was just the settings in the program. can you hear ppl ok?
Jan 12, 2009 | Computers & Internet
Great sound, no voices
Mine was the center speaker wire was not properly seating in the speaker. This is where all the sound for the voices come out. I thought it was something major. try checking them again if you haven't already.
Nov 04, 2008 | JVC TH-M505 System
When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Oct 01, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Coby 5.1 Channel DVD Player with Home Theater Speaker System System Logo
169 people viewed this question
Top Coby Audio Players & Recorders Experts
Ekse
Joe Negus
Joe Negus
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
