Question about Kirby G5 Bagged Upright Vacuum
Tech drive lever fell off
Was quoted $100 just to open it up. So I opened it myself, then saw on this site that the lever can fall off. Now I need some help getting it back on correctly and getting the other pieces to go back in where they are supposed to. I tried the phone number to contact this site but it just kept ringing.
  • 625 Answers
Could you supply me with a little more information? what lever are you talking about? the belt lift handle??
Posted on Aug 22, 2007
SOURCE:
Screw fell out of Sunburst -- Can't see how to open to replace.
If the screw has no head it may be a stray screw that doesn't belong there. Even if there is a missing screw in your Sunburst it would likely not cause any harm to it.
Oct 27, 2017 | Riccar Vacuums
Eurika Altima-cannot remove "EASY EMPTY
Hit it with a hammer when u put it in the open position. To slide it all the way open.
Jan 15, 2011 | Eureka 2971AV EZ Kleen Bagless Upright...
I can't keep the attachments from falling off while in use. I suspect I need new hardware, but cannot find instruction for Fein msx 636 II
Are you fully opening the lock lever when you are putting the attachments on? If you are new to the machine, you need to fully open the locking lever on top, insert the attachment and be sure it "seats" in the shaft holder and then close the locking lever and be sure it is tight.
Sep 14, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Kenmore 31913 Foot pedal release lever broken-need to replace
FixYa techs - thank you for your response but I solved the problems. It took me 2 hours of continual searching but I finally found the parts - listed under the tab sew machines of all things!? There is one pedal in stock and I called the service company and will pick that up and do it myself. I took that part off my vac and put it back on so know I can do it. I've been fixing stuff all my life and it just takes some logic - anyone can do it if they have a tool kit.
Nov 24, 2008 | Kenmore 31913 Progressive Direct Drive...
I have a kirby ultimate g diamond series. The tech drive lever just fell off. How can I fix this?
Ouch...
You need new pedal assembly. Just Google 558401S . I saw one for $16.10.
You can try to fix it just you would have to install it back at a certain angle. clean shaft very well with alcohol so it is completely grease free and use a drop of superglue. However this is not likely to hold for longer period of time.
Good Luck
Oct 30, 2008 | Kirby Vacuums
Floor cleaning / tools or pretreat lever appears to be broken
That grey lever needs to be closed while floor cleaning. You only open it when you use the hose.
Mar 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Kirby G5 Transmisson
I know the lever you're describing, but it's very hard to tell someone how to put it back on. There's nothing wrong with your transmission, by the way, this is a part that's meant to be moveable, and it just happened to slip off in your case. You may call us at 1-866-509-1952, and we can do our best to help you.
Jul 01, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
185 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
