I pulled the plastic tubing out of the water inlet valve and the metal retainer came with it, instead of pushing the collet to release the tubing and pulling the tubing out. Can I use a compression fitting collet with metal ring on it to attach to the water inlet valve or any other suggestions to not buy a new water inlet valve. Thanks
SOURCE: Water Leak
Your local plumbing or hardware store should be able to handle your parts request for those items, unless you insist on dealing with the MFGR...accordianman
SOURCE: Installing new inlet valve
mike most water valves not are easy to repl the dispencer li and ice maker line are just push in all the way and they lock in place and to remove the all you do is push the ring around and they get relase. now the main line that supplies water that one you have to screw right you need new connectors.
SOURCE: Plastic hose connection to water valve is leaking.
The fitting is called a John Guest fitting. It has a couple of o-ring seals inside. Once the tube is pushed into one end it is locked in. To remove, push in on the tube (opposite of what you would think to remove) then hold down on the ring around the tube, then pull out. There is a good description on this website below
http://www.johnguest.com/
SOURCE: There is a water tube
Here is a link to the parts you may need. Not sure exactly which one you need so I am posting all the water entry parts just in case.
Water entry tube
Tube clamp
Here is a video that may help you. YouTube also has quite a few other videos that pertain to this problem also. Give them a look.
