Question about KWorld PC to TV (0872880887527) Video Capture
Connection Problems I've connected it to my personal computer several times thinking maybe my cousin's computer because she is running Windows 98 wasn't able to support it. But it doesn't even work on my computer. I've hooked the wires correctly, and messed with the switch to make sure that wasn't the problem but alls I get is a blank screen on the television.
0 characters
1 Points
I have a excella stx check scanner which I connected to a machine running windows 7 32 bit, when running the demo program the first time everything works as it should, if I close the demo and reopen I can...
click start control panel in the top right hand corner type in event viewer press enter
a window will open with a local event viewer at the top of lists logs custom views windows logs applications and service logs and subscriptions select the local event viewer you should see your error in log summary right click on it select properties this might tell you what the problem is and allow you work through your way through it (note i have not had an issue with my windows 7 ) this is only a guide for your assistance not a cure !
you might have to select other logs to find the error
hope this helps you
Aug 18, 2011 | Magtek Excella STX Check Reader PN...
Hi..i have a pinnacle pctv pro tv card and have used more than 5 years with out any problems at all using winxp...recently i installed win7 on my computer which im using a couple of days but still cant...
In windows 7 there is a program called windows xp mode, you can run prgrams that arn't supported by windows 7 in it. It can be downloaded free of charge off of microsoft's website. If that for some reason does not work, you can install virtualbox. Either way I don't think it would be possible for it to be used in win7 because of the incompatabilities. You can ring pinnacle and ask but I dont think they will be abkle to do it sorry. Hope it helps
Jun 06, 2011 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
Hate to sound dumb, but have a new Soney lap top and can not find place to plug in telephone cable so that I can go on line. Have several other computers and each has places to plug in the wall to the...
Does it have a modem? I'm thinking you probably do not have a modem ... dial ups are generally a thing of the past. Fewer and fewer computers come with modems built in, deferring to a network (NIC) connection or wireless connection. A NIC connection looks like a telephone connection but the NIC (Network Interface Card) has 8 conductors while a modem would have only 4 or 6. Warning, NEVER plug a NIC into a telephone outlet. A NIC operates at a very low voltage ... if the phone rings while your computer is plugged in ... there will be a puff of smoke as 60 volts enter your computer ... guess what is next ...
If you have several computers and are presently taking turns plugging the computers in for a dial up ... I would suggest to you it it time for a wire or wireless network in your home. That way you can have all of your computers share your conenction ... though I will tell you in advance, your connection speed will be severly hampered due to the current speed limit of about 56,000. Cable, fIOS or DSL lines operate in the millions of bits. If you have this type connection ... you still need a modem ... just add a router to build your network, but you dont need individual computer modems.
If you are interested in building a network ... you will need a wire/wireless router and a modem. You would control the modem from a computer and you would install connection sharing from within that computer. This will allow the networked computers to share the connection you have. It similar to a client - server network in that one computer controls and then shares the conneciton with other computers. ... still it would be a peer top peer network (no computer is superior to any other computer)
Im starting to ramble ... if you are interested in a network ... research the topic and if you get stuck, post a question. There are lots of network "expert" volunteers who roam these virtual hallways.
Thanks for your interest in
Oct 03, 2010 | Sony TV Accessories
Philips SAA7130 TV tuner not scanning channels
hi try this procedure
1.go to device manager
2.then double click sound,video and game controller
3.then right click on saa7130 tv card (which is the driver u should have installed earlier)
4.then right click on that and select update driver software
5.the option box appears select browse for driver software on my computer u get two option select second one i.e let me pick from a list of device drivers
7.then u fine two collumed table manufacturer and modle.(note:uncheck show compatible hardware)
8.then under manufacturer select philips semiconductors then from model select saa7162 ,hybrid capture device and install.
8 it may warn about windows signature..some thing like that but dont worry just continue installs the driver.
10.then restart your pc
11.on windows startup it may show error like no device some thing like that .u just run ur tv application
if it works the dont forget to tell thanks
if it dosnt the sorry for wasting ur time
Jun 13, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problems transferring entire VHS tape contents
Just continue what your doing in previous just save the remaining minutes maybe the limits was approaches.
May 18, 2009 | Diamond Multimedia ( VC500) Video Capture
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | TV Accessories
Download/Installation problems
Where did you download the drivers to?
Did you extract the files from the zip or .exe ?
What kind of driver are you trying to install, maybe i can help with a step by step.
Oct 11, 2007 | KWorld DVB-S 100 (DVBS100) Video Capture
i think your tv tuner's driver has a conflict with windows vista, try to install it at different computer with a lower version of windows, if the problem still exist maybe your tv tuner's chip is defective.
Sep 20, 2007 | Zio Dazzle USB Computer TV Tuner...
Problem in Canopus ADVC-110
Maybe different OS? If your friend have XP and you have different operation system?
May 28, 2007 | Canopus ADVC-110 (77010150100) Video...
KWorld PC to TV (0872880887527) Video Capture Logo
47 people viewed this question
Top KWorld TV Accessories Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you a KWorld TV Accessory Expert? Answer questions, earn points and help others
