Question about Kenmore 15121 Built-in Dishwasher
Detergent Latch - Not Locking
When I try to close the detergent door, the door does not latch or lock shut. I am turning it the proper direction, however, it still does not lock shut. This is an older model, however, we have never used the unit. Please let me know what we can do to rectify the problem.
    Problem Solver:
  • 4 Answers
I have the same model in my apartment, did you make sure the outside dial is set to the "off" position?
If not, I know for sure you can turn the detergent door as much as you want and it will not lock shut, but if/when it's in the off position, it will.
BTW - one of the worst dishwashers I've ever seen, but if I didn't have it, my dishes would NEVER get done lol
Posted on Mar 30, 2009
Why does the large reservoir in the door that holds the detergent leaks continuoulsy?
Over time old dishwasher detergent that doesn't dissolve during a wash cycle can get crusty causing the reservoir to stick or not fully shut. Also, some reservoirs use doors with a gasket seal which loses its ability to seal after many wash cycles. Some doors like this have a latch that wears and no longer latches. Not knowing specifics, it is difficult to diagnose. I had to replace my reservoir in my Frigidaire because I couldn't keep the door closed.
May 26, 2014 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
1994 pontiac sunbird 3.1 L V6...door locking system has gone haywire. I got home, opened the door to the car, and when I tried to close the door, it would not shut. Can I unhook the battery to reset the...
Your door locks will not prevent your doors from closing, you should be able to lock the doors by hand and then close them with no problem. Take a look on the car where the door closes there will be a brass rod, this is your striker, it is what holds the door shut. This striker lines up with a latch in the door, the latch is on a spring and when the door is open it should be up, when the door closes the spring closes the latch around the striker. Check to make sure the latch is up, if it is not the door(when you try to close it) will typically bounce back toward you. If the latch is down you maybe able to take a flat head screw driver or prying device and twist the latch back up, this should allow your door to close. If you open the latch and it immediately closes it will need to be replaced. Hope this gets you on the right track.
Sep 24, 2010 | 1994 Pontiac Sunbird
I need to replace the detergent dispenser latch on
To replace the parts you have to buy a whole dispenser assemble for $100 to $200. To buy some time ... Get a heavy gage sewing needle - hold it with pliers and heat it red hot. Stick the hot end into the plastic door at the area where the plastic latch is (where it will line up with the far end of the latch mechanism). when it cools cut off most of the needle leaving one eight to one sixteenth (more or less) protruding. Use a drill and small bit to remove some plastic (or drill a small hole) on the spring latch mechanism. push the remaining part of the needle in or out to engage the hole in the latch.. this will hold awhile.
Jul 19, 2010 | KitchenAid 24 in. KUDP01DLBS Free-standing...
What does dE flashing on the LG intellowasher WD1050FHB mean?
It is an indication of door error. The door is either not shutting, locking or opening.
  1. Turn off the unit and unplug it for 5 minutes then replug and turn it on. If the problem persists, proceed below.
  2. Check the door latch
  3. Check if there is something that is caught in the door and prevent it to shut properly.Remove any stuck items that might push the door latch up or down during operation.
  4. Check if the door or gasket is damaged. Damaged door or gasket will prevent the door from latching or locking properly. Replace damaged gasket. Dis-aligned door prevents the door latch to lock properly.
  5. Check the door latch for any damage. Replace if defective.
Nov 04, 2009 | LG Washing Machines
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Detergent cap
Thanks for the model number. On your particular unit you can only latch the unit in the off position. If it still does not latch, open the door and remove all thr screws you see. Normal seven of them. Now, split the door and take a close look at the locking mechanism. Did something come loose? Is the spring in tact...Play with it and see how it works,...then what must be done to repair. It is really a simple system and has been tried and tested for many years in the GE Dishwashing Units. Good Luck, Eric Campion
Mar 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Detergent latch install for Bosch SHU3307UC dishwasher
you need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
Jun 25, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Detergent dispenser
The opening of this dispenser is controlled by a wax motor for release. If you are unable to keep the latch shut you are probably looking at the spring and latch assy. This is not a hard job, but you have to open the inner door to get at the latch. Part numbers for the spring disp. flap is 912547. The latch (inside door) is 99001291. If you take your time and observe carefully the job will be easy. Catriver, post back.
Aug 08, 2006 | Magic Chef CDB6100 Built-in Dishwasher
Kenmore 15121 Built-in Dishwasher Logo
119 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
