Question about Bose Lifestyle 28 System
Home Theater install
I am converting several of my components to HD and need some assistance on hooking up the system. I have a Samsung 50" Plasma, Samsung HD-DVR, SA Digital HD DVR and a Bose Lifestyle 28 system. Since the Bose won't accept HDMI, I only want to use it for audio. Can I use HDMI on the cablebox and DVD and still use Digital Audio from the Bose at the same time. I am looking at running the cable into the Cable Box and running HDMI to the TV and Digital Audio out to the Bose. For the DVD, I will use HDMI to the TV and Digital Audio to the Bose. I will then use Digital Audio from the Bose to the TV. Does that make sense or can someone out there clue me in on what I should use. My objective is to maximize the video through HDMI and Digital Audio from the Bose.
  • 1 more comment
  • cubs1957 Aug 17, 2007
    In error in my post, I have a Samsung HD-DVD-R
    Thanks, I have an digital audio input as well as an optical audio input on the Bose. I should probably use the optical for the DVD since I won't be using it as often. Also, is there a noticeable difference in HDMI cables that I can buy for $15 vs. the Monster cables at $125?
    Does a digital audio plug use a standard RCA audio cable?
    President:
  • 2,961 Answers
Yes sounds about right what you are doing as long as you have 2 digital audio 'inputs' on your Bose to get the audio from the dvd player and cable box. Apart from your last part "I will then use Digital Audio from the Bose to the TV." The tv will only downrate the audio to two channel stereo, so its not worth puting audio through the tv as you only get stereo anyway, so might as well let the tvs speakers power it out themselves.
Posted on Aug 17, 2007
  • andrew pester
    andrew pester Aug 17, 2007
    use hdmi v1.3, gold ends, supposedly reduve lip sync problems, i get them from here
    http://stores.ebay.co.uk/ultimatehdcable...
SOURCE:
How do I hook up my HDMI Blu ray player to my theater system that doesnt have HDMI
You have a few options depending on the entire system.
Do you have the TV audio output connected to the home theater system? In that case, connect the Blu-ray player to an HDMI input on the TV. Then leave the home theater system set to the TV input, while the TV is set to the HDMI input for the Blu-ray player. This is the simplest method.
You could use an audio extractor/converter. Here's an example: https://www.amazon.com/J-Tech-Digital-Premium-Extractor-Converter/dp/B00BIQER0E . This will let you send the video signal to the TV (with a second HDMI cable) and have digital or analog audio sent to the home theater system.
If the TV doesn't have an available HDMI port and the home theater system only has analog audio inputs, you could use an HDMI to component video converter. You'd use something like this: https://www.bhphotovideo.com/c/product/770115-REG/KanexPro_HDRGBRL_HDMI_to_Component_Converter.html . (Do not use an HDMI to component cable. Those only work with some projectors.)
I hope this helps. Please add a comment with more details about your TV and audio system for more specific information.
Feb 14, 2017 | Samsung Audio Players & Recorders
Need to connect some samsung audio/video components
I'm guessing that you would like all your components to play audio through the HTZ320. In order to get audio from all these components you will need a digital optical cable from the tv optical out to the HTZ320 optical input. And some composit audio cables (red and white) from tv audio out to the HTZ320 aux input. The video and audio from the dish box, bluray, and the vcr are all going to have to go through the tv first and then to the HTZ320. Use HDMI cables to connect the dish box and the bluray to the tv inputs and composit cables (red white and yellow) from the vcr output to the tv input. If you can give the exact model of the tv I can help you sort things out further. I hope this helps you.
Aug 27, 2009 | Samsung Audio Players & Recorders
Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Download Bose LifeStyle V30 User Manual
Mar 15, 2009 | Bose Lifestyle V30 Home Theater System -...
Hd movie format supportet with samsung home theater
well, i think mpeg4 is the format u need. this format can be accepted by hd home theater. And u should use this video tool which can convert any video files to mp4. Besides, it can offer u mp4 hd format as output format. Then u will not worry about quality loss.
Have a try:
http://www.pavtube.com/video_converter/
Jan 31, 2009 | Samsung HT-TZ312 Theater System
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Bose Lifestyle 28 System Logo
443 people viewed this question
Top Bose Audio Players & Recorders Experts
Steve Allison
Steve Allison
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
