Question about Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7820N
Feeder Lid assembly broken at left hinge, need new lid assembly.
Just order a new hinge and replace it yourself! why buy the entire lid/cover?
Posted on Aug 18, 2007
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC8440 - Left Hinge Assembly broken
Brother will not sell to end users, contact a Brother Dealer in your area.
Jul 26, 2009 | Brother MFC-8440 All-In-One Laser Printer
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
How to replace Hinge assembly of Automatic Document Feeder
You can try to get a hinge @ a local authorized brother dealer. I just got mine for 20 bucks, I think that the guy ripped me off, but I needed. Once you get it, it is very easy to replace. 1St, replace the old one by removing the screw in the back of the hinge (back of printer). then pretend that you are lifting the whole automatic feeder up. At this point you will see the right hinge looks likeit it coming out. Don't pull it out completely. Just pull it enough that you can flip the feeder enought so you can uncrew the 3 screw attached to the feeder. Once you remove the broken part, install the new hinge. make sure that you screw hinge first before you slip it down to the bottom hole then screw the hinge to prevent it from moving.
PS: try not to flip the feeder too far back
good luck
Mar 23, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother Fax Machine MFC8840Dn broken hinge
you can actually by the hinge itself for only 27$
the website is here: http://www.precisionroller.com/search.php?q=brother+mfc+8440+hinge&x=0&y=0
Mar 19, 2008 | Brother MFC-8840DN (Bundle) All-In-One...
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
Doc cover open
Yes there is and I know your problem have a look at the left hinge on lid that you lift to put down an original for copying, it will be breaking apart, the switch is black in that same corner on doc feeder base, as the hinge breaks apart the doc feed lifts in that corner causing "doc cover open" cause that switch no longer gets pushed in when lid is shut
Dodgy repair - tape switch closed, but doc feeder will not work properly/can use glass.
Repair - Easy removal of three screws and replacing 20buck hinge bought from brother dealer...part no.LE8731001 Hinge assy left.
Now that's FIXYA!
Nov 19, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 Doc. Cover Open Error Message
I had the same problem, found your site and all of your suggestions. I ordered the same left hinge assembly from Vance Baldwin Electronics
Part #LP2403001 for $11.03, shipping from FL to OK was $9.23 UPS, so less than $20 and my MFC-8440 is working again! I did have difficulty placing the screws without a second pair of hands so have someone help you hold the lid. Make sure you removed the set ***** from at least the back of the left hinge assembly so that you can remove the "case" that holds the springs and sticky white parts. (Yes, I am a girl) :-). My husband will be so suprised when he gets home and sees that it works now because it was on his honey do list this weekend. Also, make sure that you replace the set screws and clean the scanner appropriately before use. I really like this site, it saved me a lot of money this time. Take Care!
Aug 22, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
82 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
