Question about HP PSC 1315 All-in-One Printer
Paper size I am unable to change the paper size to 5.5 by 8.5. I have windows xp. I can change in it word, but no on the printer preferences
    Problem Solver:
  • 19 Answers
When you go to print go in properties go to paper size the go to user defined and put the size you want the paper to be.
Posted on Mar 02, 2008
How to fix PC Load A4 printer problem
A4 refers to a paper size, so its asking for that size of paper to be loaded.
Mar 15, 2015 | HP LaserJet 4 plus Printer
Cannot print. cassette does not have size of paper windows xp
Hi there, you will have to open the print driver, and set the paper size there.
Go start, settings, printers and faxes then double click on the Toshiba, that will open the print que.
Now click on printer, then click on properties, when the properties is open press on Printing Preferences, the paper paper tab on the top of the task bar of printing preference.
The auto cassette, the first cassette and the bypass must be set to the paper that your machine is set to.
Now apply the settings that you have made. Now go to advanced and then Printing Defaults click on Paper tab and change that paper size to the size that you entered for cassette one.
Run a test print and all your problems should be sorted out.
Apr 09, 2011 | Toshiba e-Studio163 Copier
I am trying to print on a custom sized paper (4.5"
  1. Open the printing preferences by accessing the Properties / Preferences dialog box.
    For Windows 7
    • Click / Select the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the 'Page Setup' tab.
  3. Click the down arrow to the right of the 'Page Size' drop-down menu to view the page size choices..
  4. Select the size that matches the paper you are using, and then click the 'OK' button at the bottom of the screen to complete the setting.
Oct 28, 2010 | Canon i9900 InkJet Photo Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
I have a canon pixma ip4200. When printing it draws the paper in but then stops. The heads print as if the paper were there but the printer doesn't draw the paper through. please help...!
Use Fit-to-Page Printing (Windows) The Fit-to-Page function automatically resizes the image to fit the size of the page being used. Letter size image data, for example, will automatically be printed on 4" x 6" size paper. Paper sizes larger than the printer can handle will be available on the Page Setup of the printer driver but will not print unless the Fit-to-Page function is enabled. Note: The Fit-to-Page Printing function is not available when Borderless Printing is selected.
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows 2000/Me/98
  2. Click the Page Setup tab.
  3. Specify the 'Fit-to-Page Printing' settings.
(1) Select Fit-to-Page Printing.
(2) Select the size of original document created in application program. Paper sizes larger than the printer can handle will be available.
(3) Select the actual size of print media.
Click 'OK'.
I hope it helps!!!
Dec 02, 2008 | Office Equipment & Supplies
I have a Stylus photo printer R1900
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
NOTE: this method is not available when using printer drivers resident within Windows itself. If your printer driver name ends in "ESC/P2" you will need to use the first method to add the new size in SERVER PROPERTIES.
Aug 05, 2008 | Epson Stylus Photo 2100 InkJet Printer
Canon MP6oo paper tray empty
Issue: "The selected paper size is not supported by your printer..." appears after selecting the Paper Size in the printer driver.
Solution: Use Fit-to-Page Printing (Windows)
    For Windows Vista
  4. Click 'OK'.
May 15, 2008 | Canon PIXMA MP600 all-In-One InkJet...
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Printing on 4x8 cards
Oct 12, 2007 | Epson Stylus RX580 InkJet Photo Printer
HP PSC 1315 All-in-One Printer Logo
118 people viewed this question
Clive
Clive
