Question about Sony XM-2100GTX Car Audio Amplifier
No sound coming from amp
My LED light comes on, but the amp isn't working. I checked all the connections and fuses and they are all still good. What's going on?
  • Chaiver Sep 29, 2007
    The Power/Protector light comes on. It is green.
    New Friend:
    Problem Solver:
Could you please tell me how to wire up a sony amp XM - 2100GTX with one sub.
Thanks,
Randy
Posted on Aug 29, 2011
  • 113 Answers
What color leds are on?
Posted on Aug 22, 2007
SOURCE:
My 1999 Honda shadow 750cc won't start
Ok, been awhile since I played with a Honda, but I believe in the KISS method.
#1 go buy a cheap $10 meter at harbor freight, Menards, Home Depot, Lowes, etc, etc. You can't just look at a fuse and say it's good, been there done that...LOL
#2 There used to be a fuse in the headlight bucket, check to see.
#3 real simple, did you leave your KILL switch off??? If not the check voltage to kill switch, make sure you have power coming out.
#4 check the ignition wire for the starter, when key is in on position or (start) position, make sure you have voltage. If you have power, follow it to your starter leads and kill switch.
#5 check voltage at your coils, Check for voltage coming out of coils. Just because you may or may not have spark, doesn't mean you have enough to start bike.
When you hooked in the LED's you either shorted wires to blow a fuse, over loaded a wire and possibly burned it in 2. Or you dislodged a connection someplace. Go back over everything you did again, and go buy a meter.
May 22, 2017 | Honda Motorcycles
The amp does not work at all even though the lights on the amp come on but when i connect it to the guitar no sound whatsoevva i checked the sound nobs on the guitar and the amp n all r ok but no soun
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Aug 06, 2012 | Marshall Amplification Marshall MG15FX...
I have a 2005 Kawasaki z750s. Both headlights went out at the same time. My tail lights and all dash lights work. Is it a fuse or wiring?!
Possible water damage to head light relay in the fuse box under the seat or the stator which controls the head light relay. Get a auto electrician to do an trace check on the wiring & connections to rule out all other faults. If the lights cut out after an heavy bump and come back on after a set time, the fault could be the relay or stator. Have the auto electrician resolder the relay connections in the fuse box (about 40 connections), also have an 12v LED warning light fitted to the stator connections with enough wiring so the LED can be mounted on the handle bar. If the LED cuts out the stator is at fault(very costly), if the LED stays on the head light relay is at fault. Also better waterproof the standard fuse box , the case is not that waterproofed (easy done with insulation tape). Hope this helps.
Dec 11, 2011 | 2008 kawasaki Z750
Amp worked shortly, now no power
It sounds like you clipped the amp and did damage to It and possibly the speakers. I would check all connections and wires first. If you used too light of wire you may have either burnt the insulation off or burned through the wire. High power amps need large power cables. If thats all ok, did you have a fuse from the pos power terminal? Check that. If every fuse is good and the connection are good then it sounds like you may have blown an internal component in the amp such as a Transistor, Diode, or Capacitor. This would mean taking it to a service facility.
Jul 19, 2009 | Car Audio & Video
Kicker zx 400.1 amp no power.. is it fried?
Well Friend, the chances that your amplifier is Fried are very low. First of all deactivate the Auto Turn On Feature on the Amplifier. Second, check that the voltage is received at the Power connector of the Lead that is coming from the Battery using the Multimeter to make sure that the Main Fuse is all right. If No Go, then check the Amplifiers fuses thoroughly. Then check if the Protection LED is lit. If it does not work after all of it, get it checked at any local radio shack as I'm sure, it cannot get fried just like that, as it is possible that some internal connection has fried or became loose and will be fixed without spending much. I wish it will help you..
Mar 14, 2009 | Car Audio & Video
No sound
check ur fuses box for a blown fuse or if ur amp has a fuse check that as well and if blown u might have to change ur fuse if not ur amp is blown
Feb 18, 2009 | Car Audio & Video
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Sony XM-2100GTX Car Audio Amplifier Logo
155 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
