Bizhub 500 trouble code
C-6701 ACC abnormality.
what does this means
    New Friend:
All sharp AR printer Error code call for solution on 08100527856 for expert
Posted on Jun 13, 2013
3 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Posted on Oct 12, 2008
  • 15 Answers
SOURCE: SERVICE PROVIDER OF BIZHUB 210 AT VISAKHAPATNAM
Put the machine off then turn on the power switch with the stop key held down
Posted on Apr 16, 2009
Bizhub 420 error code 6701 how to fix
Description
AOC abnormality.
- AOC counter overflow
Causes
CCD board (CCDB) Exposure lamp (L1) L1 inverter (L1 INVVB) Scanner motor (M2) Overall control board (OACB)
May 12, 2016 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
How do I fix trouble code c- 0204 on my bizhub C554e Photocopier machine?
Tray 2 feeder up/down abnormality.The paper feed tray 2 upper limit sensor is not blocked even after the lapse of a given period of time after the lifting motion has been started.Check the sensor and the sensor actuatos.
Jul 14, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Error code 6701 in bizhub 361
CCD, Exposure Lamp. inverter board,scanner motor, or their control board, all located under the big Glass Recommend a tech
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 22, 2013 | Konica Minolta bizhub Office Equipment &...
Ihave error code c5oo c501 in bizhub 211
The C-500 - Warming up failure.Check the fuser heater lamp continuity,end the thermofuses.
The C - 510 Abnormally low fusing temperature.Verify the thermofuse and thermistor.
For reset the malfunction codes press the switch located on display right side (a little hole) wait to appaire in central left side on the display * and press 3 and touch the Trouble reset mode.,and press Exit,the copier turn ON automatically.
Feb 27, 2013 | Konica Minolta bizhub Office Equipment &...
Error 2803 konica minolta 500
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
Dec 11, 2012 | Konica Minolta bizhub 420
Konica bizhub 250 error c255c
there is no c255c code but if it is a c2555 c2556 c2557 or any other c255 code it may need a new image unit. please give more info
Oct 08, 2010 | Konica Minolta Bizhub c203 Copier
TROUBLE CODE C-2556 COPIER BIZHUB
Although you did not indicate which model you have, this code is the same for all Bizhub Color models.
The C2556 code means that the machine has detected abnormally high toner concentration in the Yellow imaging unit. Meaning that the machine sees too much toner in the Yellow Imaging Unit.
You have 2 options. Try turning the machine off for 10 seconds then back on to see if the code will clear. You can try this several times. If this does not work then you will need to call a service company to come determine if they can salvage your existing imaging unit or if it will need to be replaced. Or if you happen to have a replacement Yellow Imaging Unit you can replace it and solve the problem yourself.
Good Luck and Thank You for using Fixya.
Jun 12, 2010 | Office Equipment & Supplies
151 people viewed this question
k24674
Marvin
Marvin
