Question about Toshiba CF36G40 36" TV
Picture tv is about 10 years old. Half an hour ago the picture went to a 1 inch strip across the screen. Not the cable
  • 56 Answers
Done tv needs professional help. the Electron gun internally is no longer capable of spanning the entire screen. Not likely anything can be done outside of professional help
Posted on Aug 17, 2007
  • Anonymous Aug 17, 2007
    aka, tv repairman call
SOURCE:
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
DirecTV installed but TV reverts back to set up screen for the model.
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
Jul 04, 2008 | Televison & Video
Our screen went black no picture only sound
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. If this does not bring the picture back, then you should consider buying a new TV. The costs of a repair ( labor and parts) might exceed the cost of a new TV. Your 10 year old TV has served you well, and has exceeded the average life expectancy of 5 years. May it rest in peace in TV heaven.
Jul 03, 2008 | Zenith Z35X21D 35" TV
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
Magnavox Color TV Model #27MT3305/17
The problem I was having was that the vertical deflection was collapsing on itself from the top. I'm a tech and I am visiting web sites who experience similar problems with the Magnavox 20 MT4405 in hopes of saving them time and money."Starsong" has the right answer. Replace electrolytic capacitor #2465. It is a
10 microfarad electrolytic capacitor rated at 160 volts. Although the existing capacitor appeared good,in circuit and out, the charge-discharge time was flat as compared with a new capacitor. Plus, when the capacitor is in circuit with full voltage applied, the capacitor leaks too much. The cost of the capacitor should be under $2. It should take under a half an hour to replace. Be certain to let your set rest, unplugged, for at least a half hour before attempting to replace this capacitor. There are high voltage present around the crt even after the set is turned off. The high voltages can cause serious bodily harm. I would suggest a tech discharge the anode on the crt with a high voltage probe passing through a volt meter and running to ground. You will need a soldering iron, solder ******, solder, and I like to use a little flux for good adhesion of component to board.
Feb 03, 2008 | Televison & Video
Large Black Strip across the bottom of the (TV Cable) Picture
This happened to me too and i fixed mine by going into settings and for some reason my subtitles were turned on. turn it off and it should fix it.
Jan 14, 2007 | Hyundai ImageQuest HQL320WR 32 in....
Televison & Video Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
