Hello, I have a Ruud 10 seer unit in the condo i rent...it frequently stops cooling. The fan inside never shuts off, but the unit outside won't come on often enough to cool to the temp on thermostat. When...
It sounds like the air cond is freezing up, and as he melts the ice off he evaporator coil you will have air flow again. When the evaporator, (which is the coil that absorbs the heat from your condo) is frozen over, no air flow can pass through it. The evaporator is located either above the furnace or below the furnace. Therefore, the indoor fan will continue to run, but no cool air will be coming out of the vents. What causes it to freeze up? Usually it is low on refrigerant (some people call it freon). If there is a leak in the system, he may charge it with refrigerant, and then in a few days or weeks later have to thaw it out, and charge it again. If this is the case, you might want to request the leak be located and fixed. Another reason it will freeze up is a dirty filter. Or, if the unit did not have a filter in it for quite some time, the evaporator could possibly be stopped up with dirt resulting in poor air flow all the time and and eventual freeze up of the evaporator. Hope this helps you, stay cool.
