Question about Epson Stylus C84 InkJet Printer
Print not working
Installed 3 new ink cartridges (Genuine Epson cartridges). None worked. Tried "Nozzle Check" - no lines for the new colours. Took out one, and shook it - still did not work. Turned printer off and on again - still nothing. Note - all 3 were really low when I replaced them, because after the first replacement did not work, I tried the "Nozzle Clean" function at least 3 times, so it ran the other 2 cartridges to less tha 5%.
  • Epson Master
  • 705 Answers
Follow the instruction in my previous post on under head cleaning. Complete the routine and see if any improvement is achieved. If not you may have a problem with the tubes connected to the cleaning station. This will require pulling the machine apart and is to detailed to enter into here. You could contact http://www.TheServiceManualShop.com for info on the countermeasure for the loss of suction and a service manual to help you pull it apart. Try the cleaning first though -> http://www.fixya.com/support/t138226-printer_not_printing Let me know how you get on.
Posted on Aug 17, 2007
How do I stop lines on the epson 4515
Cleaning only helps if there is still ink in the cartridges.
If you print the nozzle check, you can see what colour is having problems to print.
And when you are sure there is still ink in the cartridge, you could try to remove the cartridge, and in the printer, where the cartridge was, you could put a drop of cleaning fluid in the nozzle on the bottom. Then try printing one or two pages on full colour, till the ink starts coming through.
Be aware, sometimes just a bit of dust is traveling wit the print head, blocking the ink too. But then you see smear on the paper.
Always be sure the underside of the print head does not have debris traveling with the head.
Almost impossible to see, but epson sometimes delivers special cleaning paper. It is a pice of paper, with a special pice of sticky tape. Sometimes it comes with the Ultra Glossy Photo Paper. Use it.
Aug 21, 2014 | Epson Office Equipment & Supplies
BLACK INK NOT WORKING
Black ink head clogged/cartridge empty. Go to Printer Utility and do a Nozzle Check, Print a Pattern. If Black pattern lines are missing/broken then do another cleaning. Don't forget to try a new cartridge if the cleanings do not work. Refurbished Epson printers are great and can be purchased at www.epson.com/clearance. I have used them for 15 years.
Feb 15, 2013 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
I have bought new genuine Epson ink cartridges, installed them correctly and although the settings are recognizing that there are 4 full, genuine cartridges it is not printing any black ink. I have done a...
I know it sounds stupid but do you have the old black cartridge, if you do put it back and see if it is printing even if the quality is poor and faded. If it is then possibly there is a contact bad, try swittching the black cartridge for one of the other colour ones, but put a colour in to the black space but don't put the black into one of the colour spaces. If the colour one is working in the black space then it's basically a dud cartridge and bring it back to where ever you got it from. Hope it works for you - Pat
May 16, 2011 | Office Equipment & Supplies
Will not print one colour
theres your first problem, restrain from using non original/genuine inks because it might lead to a more serious error in the future, one solutions you could do is to check the nozzle of the yellow ink, it is the pear shaped just where you insert the ink cartridges, check for clogs, there are about 4 to 6 holes, all of them should be clog free. try also cleaning the copper terminals, it is where the copper terminals of the cartridges meet, clean it with a cotton cloth, try NOT to touch them, specially with an oily hand. it is where the signals from the printer relays to the cartridge when to spray ink.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hi, when printing the page is full black. After head clean, nozzle check etc still black & nozzle check prints two x dark lines. I changed ink cartridges but no improvement. Thanks, Roger
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
Hello! I don't use my Epson PictureMate as often
That is a problem with the Ink jet printers. Lack of use causes the cartridges/heads, etc. to dry up. You're only solution (I'm afraid) is to replace them.
TIP: If you're typically not using the printer for several days or even week(s) at a time, it never hurts to print a single (low coverage) page of colour every few days just to keep the ink flowing
Jul 10, 2009 | Epson PictureMate C11C623001 Photo Printer
Not printing magenta ink and tried cleaning heads already
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus dx4400 Printer printing in pink
have you tried nozzle check? it should tell you that the inks are not printing correctly it will print on a pattern of lines if there are gaps and breaks on the lines it means that you have to clean the heads. check on your manual how to do it. what is your operating system on your computer? Windows or Mac?
Feb 10, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus C84 InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
