Question about Dell Latitude Cp, Cpi, Cpx, C600, C800, Inspiron 3800 8000 4000 601212 CD-ROM Drive
Blue error screen when starting up computer
When I power up my laptop, it looks like everything is going fine....until it gets to the Microsoft logo screen with the start up blocks at the bottom. The blocks of blue only get to half way when it pauses and a blue screen error appears.
  • Phenics Jan 08, 2008
    I have the same problem with my Dell desktop computer. Blue Screen occurs after Windows begins loading. We've tried to start up in Safe Mode but cannot. New no software was recently installed but the blue screen references hardware, none of which is new to my computer. I've been having troubles with the CD Rom searching for a disk at start up and think this may be the final consequence of that attempt.
  • Dell Master
  • 12,061 Answers
Ok sounds as if you may have a possible "Driver Conflict" or the like... Have you installed any software recently? If so try booting into "Safe Mode" and Uninstalling it... To try to fix it, you have a few options... firstly you can try booting into "Safe Mode" by pressing F8, straight after turn on... when at the "Safe Mode Menu" choose "Last Known Good Configuration". here is a link to help you understand... "Safe Mode" http://support.microsoft.com/kb/315222 Please find a link below to repair ya install if trying last known good, software removal etc, don't work.. http://www.webtree.ca/windowsxp/repair_xp.htm Just take it easy step by step.. ya will be back to bits in no time :)
Posted on Aug 17, 2007
SOURCE:
How do I factory reset a blue gear Microsoft nb10t01 laptop computer
https://support.microsoft.com/en-us/help/4023533/surface-restore-or-reset-surface
Can't sign in or start Windows?
  1. Press the Windows logo key +L to get to the sign-in screen. ...
  2. Hold the Shift key down while you select Power > Restart in the lower-right corner of the screen.
  3. After your Surface restarts to the Choose an option screen, select Troubleshoot > Reset this PC.
Aug 15, 2018 | Microsoft Computers & Internet
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Hi, I have a problem with my laptop(2 yrs old). When I turn it on, it shows the microsoft loading screen with the logo and all, but after that the computer screen turns black-- not completely black, but a...
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
Oct 23, 2010 | Sony VAIO VGN-C140G/B Notebook
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
Windows dosent start
go n format it by using a recovery drive...there may be a start up errors occured in windows
Apr 26, 2009 | HP Compaq nx6310 Notebook
It starts up fine until a blue screen pops up
hi
i think one of the drivers are the culprit. heres what you should do:
open your system unit and remove all the pci cards except the vga card. and turn on the computer.if it starts fine, then turn it off and hook each card one by one.
hope this helps
Kind regards
RAhL_hunk
Mar 06, 2009 | Microsoft Windows 2000 for PC
Blank screen laptop
Your SONY should respond to the following:
Look for the blue FN key, hold it down (use it like a shift key)
While holding it, look for a key, also printed in blue with a picture that is half sun/half moon. On my laptop is the F8 key. As you press the key watch the screen to see if gets lighter.
Good Luck!
About Me:
Carl DeAlto
DeAlto Computer Solutions
http://www.dealtocomputer.com
Jan 17, 2009 | Sony VAIO K45 Notebook
My HP Pavillion desktop had given me a "serious error" screen and then a "blue screen" and stopped working. It would not reboot. I had to use my recovery disc to get it to boot up. It...
you need to make a note of that blue screen you say you get when the computer stops working.. those are know as the infamous blue screen of death (no kidding) or as ms call it stop error screens..
make a note of the stop error code you get on the screen.. it's way to fast for you to see it.. you may be able to see what the stop error code is by going into the event viewer (as long as you have checked to have this events reported to event viewer in system properties> advance tab and start up and recovery area.).. look inthe event viewer (start>right click my computer>manage>event viewer) and look for system events.. you should see a white x inside a a red circle.. look for those error events and look for the error code.. it should give you something like 0x????????? post that error here.. or google it, it may give you an idea of what may be wrong. at this stage it could be software related or hardware related?
did you install a device recently? the driver is very comun problem that may give you a bsod if it's critical.
Sep 21, 2008 | HP Computers & Internet
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Aug 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
682 people viewed this question
Ekse
Clive
Clive
