Question about GE PSC23NHN Side by Side Refrigerator
GE model TFX24FA side by side
Freezer stays cold, but the refrigerator stays at about 60 degrees. Built in computer shows all systems nornal. Can you help? Thank you.
  • enerarevir1 Sep 23, 2008
    My TFX24R works fine for a few days then stops cooling. It thaws everything out in the freezer and won't come back on. Sometimes, if I slide the refrigerator slector to of and then back on, it will stat. Sometimes, I have to "tap" on it and it will start back up. Help!!!
    I love this frig and would like to keep it.
  • 3 Answers
If solution #1 fixes the problem, but it happens again, then check to see if you have water leaking from the ice maker area. I had a similar problem with my same model, and found that the ice maker water fill tube was leaking where connects to the connector in the back wall of the freezer. Water was leaking onto the freezer coils, causing it to go into defrost for long periods and both the freezer and fridge would warm up.
Getting to the fill tube is not an easy job. If you just pull it out without disassembling the fan compartment, you will probably not be able to get it back in.
You will likely want to move your food, unplug the fridge and thaw it out. Disassembling the top compartment on the inside of the back wall of the freezer is a tedious and time consuming task. After that I was able to just pull the tube out and turn it around and push it back in for a snug fit. You might consider using a sealer.
Posted on Apr 03, 2009
    Novelist:
  • 87 Answers
Look in he back of the freezer section, if you see ice on the back wall then I would suggest defrosting the whole unit overnight and restarting to see if this makes a difference to the fridge section. If it does then you have a problem with the defrost cycle of the unit, if it doesnt then you may have a fan gone. We normally suggest defrosting first in case a door got left ajar. However if it does pull back down you will need to keep a close eye on the unit for several weeks. Hope this helps.
Posted on Aug 26, 2007
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Freezer works but fridge doesn't stay cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Refrigerator is not cooling well nor freezing well
hi. did you check the freezer fan motor, or for frost build up in freezer
Oct 02, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSC23NHN Side by Side Refrigerator Logo
176 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
R.A. Ellis
R.A. Ellis
