Question about Toshiba 61HX70 61" Rear Projection Television
TV repairman blew fuses??
I had a repair man come by to take a look at my set and he used a jumper wire to do something I am not sure what I was in the front turning the tv on while he was in the back of it. I heard a loud pop followed by some chioce words from the repair man. he sadi there was some smoke back there and that 3 resistors were blown. I am assuming he blew these. He then said that he could not fix it at my home that it would need to go to the shop and that he would need at least $400 and could not guarentee that would fix the problem. O nthe work order he stated that the IC fuse was open on B+, would that be the flyback??
    Problem Solver:
  • 9 Answers
...repairing any electrical and electronics devices like you said high end television set is in fact no joke to handle and any personnel attempting to fix any internal problems requires a lot of knowlegde and not just guessing.. but because he blew up somthing does not neccessarily mean he blew up the flyback component.
.... for now pal i guess you better find appropriate service center to handle that exact type of television. or the authorized service center in short.. good luck..
Posted on Jan 31, 2008
    Scholar:
  • 173 Answers
Yes maybe ...but he made problems alot worse bypassing your fuse, the fuse is there to blow if you have a short and not harm other components. my guess is that he damaged your power supply and then fixing that youll still have the orginal problem. I think I was the only tech in Houston that could troubleshoot. Sad, but very few good tv men or big screen. we trained are outside guys not to touch much but do slight adjustments and bring it into shop if you dont have a clue and they make some story up to the customer. good luck
Posted on Aug 17, 2007
SOURCE:
Bulbs blew on my nutone allure range hood new bulbs does not work. please help
Depends what is wrong.To call a repair man will cost a service call before he starts. Check all your wiring and see if there is a short. See what you can do before you call a repairman.
Nov 04, 2014 | Broan-NuTone Kitchen Ranges
Tv went dead then we smelled "electricity" smell like something blew. tv is completely dead. any options?
sounds like a blown internal fuse. unless you are savvy with a soldering iron you'll need to take it to a TV repair man. i assume its out of its warranty period?
Mar 24, 2014 | JVC LT-47X788 47 in. LCD HDTV
Speakers stopped workin in a 2000 Suburban
If you have a non-original stereo, there may be inline fuses in the wire harness leading to the stereo. Look under the dash with a flashlight and see if you can find the harness. Alternatively, you can pull the stereo from the dash and look at the wires that way.
The speakers can be checked by using a 1.5 volt battery. Unhook the speaker wires from the back of the stereo. Then, using jumper wires, MOMENTARILY connect the battery to each pair of speaker wires. If the speaker is good, you will hear the speaker cone move (it will make kind of a scratching noise) as the battery is connected.
If the speakers check out, and you are SURE that the stereo is receiving power and ground at all the correct points, then I'm afraid that your stereo is likely damaged.
Jan 05, 2014 | Chevrolet suburban player. stereo...
I have a 2006 Hitachi Plasma 42HDS69 that will not turn on. When you power up the TV, the fuse blew. Replaced fuse, powered up the TV, could hear relay click in and fuse blew at the same time. Is this...
You have defective power supply board, Are you OK to strip it down and inspect the board? You will either have to replace the board or have it replaced/repaired professionally.
I hope I have been of help
Feb 14, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I turned the tv off the other night with the remote just like i always do got up next morning to turn it on it won't come on I have tried everything unplugging it pushing the power button on the tv instead...
Good day sir/maam, chances are you tv's switching power supply circuit has gone bad, you may try the following.
  1. open the back cover and locate the fuse, check if the thin wire is intact, (unplug the unit before opening the back cover) replace and test if the fuse blew up. test again.
  2. if the fuse is intact. replace the cover.
At this point. you have no choice but to call your dealer or repair man for service.
Oct 08, 2009 | Panasonic CT-36SX31 36" TV
Electrical short radio 2005 ford explorer sport trac
THE RADIO MOST LIKELY IS THE PROBLEM, WITHOUT THE REPAIR MANUALS IT WOULD BE VERY HARD TO REPAIR (man. not availiable to the public), YOUR BEST BET IS TO FIND A FORD AUTHORIZED REPAIR SHOP, THEY ARE ON THE NET, THE OTHER BUY A USED UNIT ON EBAY, THE LAST IS THE BEST OPTION, I HAVE DONE THIS ON SEVERAL CARS AND WORKED OUT GREAT, LESS THAN $100 FOR A USED UNIT.
Nov 04, 2008 | 1998 Ford Explorer
EFI fuse blows
You have a short in one of your fuel injector wires. Check the wires from your fuel injectors for burns or cuts, look for bare wires grounding out on medal
Jun 30, 2008 | 1992 Toyota Pickup
RCA P61927 61 in. Rear Projection Television
get a tv repairman out to make sure of the problem, it might be xomething simpler he can fix but it sounds like the convergence board is out
Jun 21, 2008 | RCA P61927 61" Rear Projection Television
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
No red in picture
If this happened at the same rime that the repairman replaced the IC's in the set, I would say he is responsible to repair this problem. I would tend to think that the red picture tube socket is loose, or the repairman pulled a cable or connector loose, unless he turned on the set while something on the chassis was touching something else and blew something out. Good Luck
Jun 03, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 61HX70 61" Rear Projection Television Logo
191 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
