To turn your bluetooth on do the following process.
1.Click
Start , type wireless into the search field, and then select
HP Wireless Assistant from the list.
2. By default, the Status column shows that both of the wireless devices are either on (enabled) or off (disabled). Also, by default, the Action column does not display.
If you want to control one of the wireless devices individually, without affecting the other devices, click
Properties , and then select the
Independent controls for installed wireless devices option.
If you have removed the HP Wireless Assistant, it can be reinstalled using the Recovery Manager service.
- Click Start , type recovery into the search field, and then select Recovery Manger from the list to open HP Recovery Manager.
- Select Advanced options .
- Select Software program re-installation and then click Next .
- When prompted, click Next .
- Select HP Wireless Assistant and then click Next .
Follow the on-screen instructions to complete the installation of the HP Wireless Assistant.
You can verify the device is installed & enabled with Windows Mobility Center.
To turn Bluetooth devices on or off, do the following:
- Click Start , type mobility into the search field, and then select Windows Mobility Center from the list to open the Windows Mobility Center.
Alternately, press the windows key and the letter x key at the same time.
- Use the drop-down menu items in the Integrated Wireless Devices selection to turn the devices on or off.
I think the above tips are helpful to you.
Thank you for using fixya.
it only work when an available network is around...maybe the network you seek isnt wlan...
