Question about Samsung SGH-E900 Cellular Phone
Format i have had 2 memory cards,both of them i have had for about 1month each and with both of them it came/comes up with 'unrecgonised format' and i dont know how to solve the problem. its also making my phone go all funny! please help!??
  • harri8 Aug 17, 2007
    Thnks for your help x
    wat type of memory card shall i use then??
Memory card is not good, try another memory card microsd. king o another memory card 512 mb.
Posted on Aug 17, 2007
SOURCE:
Hi i loackd my memory card few mnths ago and nw i forgot the password i tried diffrnt paswrds but its stil locked,,,n it gvs option of formating it but i dont want to loose my images vdos n muzik...kindly...
Memory card in a locked condition, the data can be saved. There are two ways you can do:
1. Use the data recovery software (must be software full version). How: insert memory card, run the data recovery process, select the drive memory card, etc. Save the file to your hard drive recovery. After the data saved, memory card format (quick format), then restore the data into the memory card.
2. Quick format memory card, and do the data recovery process. So that data can be saved, do not do a full format, but do a quick format. Tools such as hard drives, flash drives, memory cards, when done quick format, data can be saved.
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
My 2 gb Micro sd card can not format and 0 byts memory card
dont worry ............please connect your card with pc and press right key then select property after its please disable read only property and format .............then your card will be format..........
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
Memory card is not working. The red light comes on the camera and said the memory card needs formatting.
Hi, why you not try to format the memory card?maybe you dont want to delete or loose the picture. Try to save you picture first to your computer and then format the memory card to the camera.
if the problem still occur tryo to use another memory card and you will found what is the problem is it memory card or camera.
good luck and thank you my friend
Jul 17, 2010 | Kodak EasyShare CX7300 Digital Camera
Good morning sir, my nokia 3110 classic recieves viruses from where i dont know. If i put my memory card in the phone and dont use it for along time my memory card gets affected.
VIRUS/FORMAT
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
Jun 23, 2010 | Nokia 3110 Cellular Phone
My memory card will not work in my samsung a501 cell phone. when i place it in it comes up with "this memory card has an unrecgonised format" it also says"reformating will erase all the data do you want to...
HI,
This is the problem with your memory card, your memory card is corupted and wont work anymore
Try replacing it...
RATE THIS SOLUTIoN
RNJ VINOD KUMAR
Jul 17, 2009 | Samsung A501 Cellular Phone
PS2 Memory Card "Unformatted"
DNT FORMAT IT if you do then it will just unformat its self when you turn it back on i have the same problem if i was you i would try deleting some stuff off the memory card (turn the play station on with out a disk in and click on memory card) than delete some old data you dont want. but if that still dont work then try blowing in the memory card (it might be a bit old). after you have done all of these things and it still dont work then i would go on a website about sony play stations and unformating memory cards, and there will be a phone number ring it tell them whats happened and they will surly send you a new memory card but that would meen your old memory card would have to go in the bin :( its a plesure to help.
May 30, 2009 | Sony PlayStation 2 (PS2) Console
Memory card says ''not formatted''
try to insert your memory card to other mobile unit bt if it has a same problem you have a corrupted card.
no other choice is to change it.
thanks,
May 16, 2009 | Nokia 7373 Cellular Phone
Samsung rant memory card problems.
hi there, it happens some time but dont panic
try these things
switch off mobile
take the battery and memory card out
wait for 2 min
put the things together
and turn the mobile phone on
it will work...
or
take the memory card out
put it in the sd card slot on your laptop or in external card reader
format the card
(when the format option comes selet 'FAT' not 'FAT32'
press ok
take the memory card out of the slot/reader
put it back
wait for a minute
turn the mobile on
and it will find the card
(but be sure the card inserts in a correct way.
hope it will help you.
Mar 24, 2009 | Samsung Rant Cell Phone
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 | Nokia 6600
Can not format sandisk 2 gig memory card in samsung d900
Check wether your phone can handle the capacity of the memory card. Some phones can only handle up to 512Mb memory cards. Consult your phone's user manual.
Aug 15, 2007 | SanDisk Memory Media
Samsung SGH-E900 Cellular Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
