Question about Miele S251i Plus Bagged Canister Vacuum
Will not turn on
The vacuum was working fine and it suddenly turned off while it was running. The vacuum had a new bag and the filters were not dirty. It will not turn on again. I tried to plug it into different outlets, but it will still not turn on.
  • Anonymous Nov 02, 2007
    Intermittent stop start. Probably loose connection at cable-winder end. How does machine open please?
  • Anonymous May 08, 2008
    I was vacuuming, and the vacuum turned off. It is a bagless Hoover Windtunnel 2 Extra Reach.
    Problem Solver:
  • 6 Answers
Your problem is probably a bad male cord end or the there is a problem with the cord winder. It might need a spacer.
Posted on Oct 10, 2007
SOURCE:
Will not turn on, question mark sensor is on
This is because the filter bag has been removed and you need to install a new filter bag....Once the filter bag is installed, the unit should run as before.
Sep 14, 2013 | Electrolux Lux 5500 Canister Vacuum
I have an older model Electrolux canister vacuum and it turns off quickly after turning on and this checkered light comes on. It happened right after i finished cleaning the ashes in my stove which i...
Make sure there is no obstruction anywhere along the hose. Also properly clean the filter and collection bag. This may have become blocked due to the fine ash, sort of sealing the bag.
Jan 02, 2018 | Electrolux Guardian Bagged Canister Vacuum
All fo a sudden, no suction, motor runs fine, no clogged tubing.
Be sure the upper attachment hose is inserted firmly into the lower hose into the nozzle. Check for suction at the end of the hose, and if there is no suction there must be an obstruction in the hose, or the filter inside the bag compartment is plugged. Be sure the brush is turning when the handle is released.
Jan 18, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
My Oreck vacuum cleane won't turn on
I have an Oreck vacuum. My son used it just earlier today and it worked just fine, then just a little while ago a tried to turn it on to vacuum our bedroom and suddenly it won't turn on! I tried plugging it into other outlets but it was no use. My husband takes a look at it and first thinks that the switch is out in it. He takes the handle apart and quickly realizes that it is not the switch that is causing the problem. Then he took the base of the vacuum apart, removes the spin brush part and cleans it off, puts it back together, and suddenly it works! He said that when those brushes get real dirty the motor gets clogged, then it just won't turn on. I'm just happy I married someone who can figure these things out, because even if I knew the problem I'm still no good with a screwdriver, taking things apart and putting them back together again. Hope this works for your Oreck too and it's running again for you soon.
Jun 18, 2010 | Oreck XL2200 Bagged Upright Vacuum
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
When turned on the sound is like its screaming. It appears to be coming from the filter compartment. It all seems to work ok.Thanks
I suggest checking the filter. If it's coming from the HEPA filter area, the filter might be out of position or possibly you have the wrong kind of filter. Miele uses 2 different types of HEPA filter so that could be the problem.
Aug 23, 2009 | Miele Cat Dog Plus S511 Bagged Canister...
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Dirt Devil Purpose for Pets suddenly stopped vacuuming, totally cutting off. Checked plug and outlet for problems which were negative.
I had this same problem. All of a sudden it shuts off while vacuuming and then i'd have to wait a while before it would turn back on. Finally it stopped working period. Before going out to buy a new vacuum, I decided to take the thing apart and clean it up really good. That included running a clothes hanger through the tubes to get all the stuck hair out, removing the roller and getting all the hair untangled from it, and rinsing out the air filters (both the sponge and the plastic piece with the paper like filter) with hot water. Then you let the filters dry for a day or two. The plastic/paper filter takes longer to dry so I used a hair dryer. The vacuum itself is not hard to take apart. I think there are only 11 total screws you need to take out. After the filters dried I put them back in the newly cleaned vacuum and it worked like new. I think the main problem was the condition of the filters. They can get pretty filthy over time, which will limit the air flow to the motor. With less air the motor is more likely to overheat and shut off. So keep your filters clean and you shouldn't have any proplems.
Apr 03, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Miele S251i Plus Bagged Canister Vacuum Logo
329 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
