Question about Metrologic Instruments 9520 Voyager
Scanner blocks when scanning a bar-code
Hi, I just bought a Metrologic 9520 bar-code laser scanner. Everytime I scan a bar-code (I've tried many different bar-codes from different products) the scanner beeps once and turns the flashing green light into a fixed red light and it stops scanning. In the installation guide it says that that means that the scanner is waiting for the host to return confirmation or something similar. Do I need to configure anything prior to use? In the store the seller told me that the scanner came out-of-the-box with a preset configuration which would work fine. I've tried disabling and enabling the different bar-code standards scanning the configuration bar-codes from the configuration guide. When I scan the bar-codes in the configuration guide, the scanner works fine. If I try any other bar-code, the scanner blocks and I have to unplug it and plug it in again. The software which I'm using for my clothing store admits bar-codes, butIt doesn't receive any information. Any help, please? I'm in a hurry!! Javier Chico
  • jchico Aug 17, 2007
    Thanks for the answer, but this barcode scanner comes with no drivers. In Metrologic's web site, there is no drivers for this item. Even, in the installation guide thre is no mention to the driver.
    I'm using a laptop computer to host the application. It only has one PS2 port, could that has something to do with the problem?
    Thanks in advance for your help,
    Javier Chico
  • jchico Aug 20, 2007
    Could someone tell me how could I solve this problem? The laptop only has one ps2 port. How could I make that port only for keyboard so that the scanner works fine.
    Thanks in advance,
    Javier Chico
  • 3 Answers
The metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
  • 661 Answers
Is doesn't sound like a problem with the Barcode scanner itself, this sounds like it may be a driver issue, the scanner will power up and scan barcodes with only the power connected, however it is the drivers and associated software that channels the data from the device into the system, I reccomend that you check "Device Manager" for anything listed under "other devices" load the drivers from the driver disk that came with the device or download updated drivers from the manufacturers website
Posted on Aug 17, 2007
  • 1 more comment
  • Gareth Cockram
    Gareth Cockram Aug 17, 2007
    ah... I see... This kind of device is known as a Keyboard Wedge, no drivers are required, her it needs to be plugged in to the keyboard port, as well as your keyboard (plugging it into the mouse port will not work), usually ther is either a y-cable or a special T-piece whyou use to plug this and your keyboard in to the same PS2 port.
    I thought you had the usb type....
    I hope this clarifies
  • Gareth Cockram
    Gareth Cockram Aug 22, 2007
    Hmm, not sure exactly how to do this one,
    If you plug a PS2 keyb into the port and use the y-connector this may work, but then you are lugging a keyboard about with you too, I am fairly certain that it needs a keyboard to be connected for a keyboard wedge to work (as the computer needs to detect the keyboard),
    The easiest way around this prob may be just to buy the USB cable, (as keyboard wedges are tricky to get working especially on a laptop)
    Metrologic part code is MX009
    you will have to ensure that the Drivers are installed correctly (as previously stated) for use on USB.
  • Gareth Cockram
    on a further thought, (I was looking at data for another scanner)
    If you have the programming sheet, there is an item called KEYBOARD EMULATION, if you set this to on the scanner pretends to be a keyboard, so this may be a solution if your scanner is capable of this
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Barcode font problem
Try going to the manual and scanning the setup code for accepting a the I2of5 code.
May 21, 2010 | Metrologic Instruments 9520 Voyager
We recently received another 9520 from Honeywell to replace a faulty one. For the non-tekkie, how do I configure it for use with library scanning for books?
Bar Codes The MS7120 can be configured by scanning the bar codes located in the MetroSelect® Single-Line Configuration Guide. This manual is available for download at http://www.honeywellaidc.com/site.aspx/na/en/product_center/product_support/?category=5&product=297
Please let me know if you need further assistance
Kim Ganoe 800.933.2839 x251.
Mar 23, 2010 | Microsoft Metrologic MS9520 Voyager...
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Ms9520
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
Metrologic 9520 help...Please
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Jan 19, 2008 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
1,097 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
