Question about RCA Lyra RD2215 MP3 Player
Rca lyra tc1501fmb won't start
Rca flashes on screen computer can't download driver battery charges
Well, in my case the driver installed fine, and I have been using it for weeks now, this is a problem that came up recently for me.
Posted on Nov 13, 2007
  • 1944 Answers
SOURCE: Need a driver for RCA Lyra RD2840
You can download here from RCA.
Posted on Feb 03, 2008
lo formatie y solo sirbe como memoria no reproduse la musica
Posted on Aug 30, 2008
SOURCE: rca lyra rd2760 doesn't change from "RCA LYRA" screen
I would try downloading the latest driver, or reformatting the unit. If you haven't downloaded anything, you essentially have nothing to lose, so to speak!
Posted on Sep 05, 2008
  • 16 Answers
SOURCE: Vista & rca lyra rd2780
If you boot with the RD2780 plugged into the USB, Vista will recognize it.
Posted on Mar 24, 2009
  • 909 Answers
SOURCE: Have a RCA Lyra Mp3
download "media monkey". its a free media player, cd ripper and mp3 sync, it will do all you want and more. just google it.
Posted on May 01, 2009
0 characters
1 Points
MP 3 player is frozen - removing battery doesn't help
You will be able to restore the functionality of you Lyra after you reinstall the firmware you can download from the manufacturers website. This is a very common problem for mp3 players.
Here are the instructions once you have downloaded the file.
We highly recommend you do not connect your player to the computer until Step 3.
  1. Locate the downloaded RD2010/11/12/15 upgrade file and double click it.
  2. Following the onscreen instructions, allow the program to completely install all USB drivers (Windows 98SE and Windows ME) as well as the upgrade program and firmware. You may be required to reboot once the install is complete.
  3. Connect your RD2010, RD2011, RD2012, RD2015 to the PC using the USB cable.
  4. From the “Start” menu, select “Programs” > “Lyra™ Personal Audio Player” > “RD2010, RD2011, RD2012, RD2015” > “Update Device.”
  5. After the program is finished searching for the device, drivers and new hardware may be detected and installed. Then the “Update Lyra™ (RD2010, RD2011, RD2012, RD2015) Device” box will pop up with current version and new version (1.51) of firmware shown.
  6. Press “Start” to update the firmware of your Lyra™ RD2010, RD2011, RD2012, RD2015. Depending on your existing firmware version, the Upgrader might show an option for formatting the device. Click “Yes” to continue.
  7. When the update is complete, click “Close.” If present, use the Windows system tray icon to safely disconnect the Lyra™ RD2010, RD2011, RD2012, RD2015 and unplug it from the USB cable.
    Your update is now complete.
I hope that helps.
Nov 24, 2009 | RCA Lyra RD2010 MP3 Player
Rca lyra rd2840 firmware download
Check the follwing sites:
By the way, the only I did just was Google the internet and look for "RD2840 firmware download"
Best regards,
Jun 27, 2009 | RCA Lyra RD2840 MP3 Player
go to the website and download the new software for your player..
Mar 26, 2009 | RCA Lyra RD2765 MP3 Player
Wont connect to pc
Try a new/different USB cable. My Lyra was a painful thing with cables. Also, make sure the plug and receptacle are clean. Improper connection can do this.
Also, you should have gotten a driver CD for the player. It contains the correct drivers for the lyra, and will help Windows XP use the correct USB drivers.
Try those and see what happens. It may just be corrupted USB drivers.
Hope it helps bud!
Sep 21, 2008 | RCA Lyra M2030 MP3 Player
Rca lyra rd2760 doesn't change from "RCA LYRA" screen
I reset the unit by sticking a paperclip into the reset opening. Now, I can't get the computer to interact with the mp3 player. Mp3 player is showing "USB transferring..." but nothing is getting to the computer.
May 25, 2008 | RCA Lyra RD2760 MP3 Player
Won't do anything
I'd start by replacing the firmware on it. I believe this may be the firmware for your model.
Jan 09, 2008 | RCA Lyra RD2762 MP3 Player
My RCA LYRA mp3 player isn't working!!!!!
keep turning it on everytime it turns worked for mine.afterwards plug it back in and let it fully charge
Oct 19, 2007 | RCA Lyra RD1072 MP3 Player
How does this work?
When the unit is connected to the computer, ?USB Connected? will be displayed on the screen. During transfer, ?USB Transfer ...? flashes on the display. When the transfer is complete, the display will change to "USB Connected". Do not unplug the USB cable when the display is flashing. Also, check to see if the mp3 file(s) you're transferring is between 32 to 320 kbps. You may need to reinstall the USB driver for this device. Good luck.
Jun 23, 2007 | RCA Lyra RD1072 MP3 Player
MP3 & Digital Media Players Logo
266 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
