Question about Fedders X Chassis A6X08F2A Air Conditioner
Fedders Window AC
My AC seems like it runs on fan mostly. It's not cooling. It cools when the compressor kicks on, but it doesn't stay on very long...no matter how low I have the thermonstat. Any suggestions? Thanks, Tony
  • 50 Answers
You may have thermostat problems. If the blower and compresssor kicks on, that indicates their ok. If you have a two wire thermostat, you can tie those wires together to see if the unit will operate. BE SURE TO DISCONNECT POWER.
Posted on Aug 18, 2007
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Cooling fan temp light stays on when air condition is on. fans are not kicking on. Is it the fan module ?
I didn't know it had a light on the dash that said "cooling fan temp".
My 93 doesn't.
The cooling fans are controlled by the computer and turned on when the ac is running or when the engine reaches 220 degrees.
A mechanic would check the fuse and relay for power and the fan motor for power and ground.
Aug 26, 2012 | Cadillac DeVille Cars & Trucks
Compressor keeps kicking off 1999 Buick Century AC
Your ac system is most likely low on freon, or the cooling fan is not working.
When you turn on the ac the cooling fan should stay on.
If it stays on then you are low on freon.
Nov 23, 2011 | 1999 Buick Century
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
The fan is coming on but the compressor is not.Even after the unit has been off all night (long enough to cool down or ice to melt) the compressor does not come on.
All window unit compressor have a thermal breaker mounted on it. It is to protect it from overload. On a hot summer compressor work harder to keep us cool. Sometimes this thermal breaker fails for good. Unplug the ac. Open it, on the compressor there is a bulging thing sometimes cover with rubber. Thats the thermal breaker. Check its continuity. If you don't have an ohmeter, just byspass the two terminal of the thermal breaker with wire. Plug it in, but be carefull, turn on your ac. The compressor should come on.
Jun 27, 2009 | Fedders AED24E7F Wall/Window Air...
DuoTherm compressor starts but will not continue to run
check condenser fan if running. it will make compressor comes on and off if broken
May 31, 2009 | Dometic Rooftop RV Air Conditioner
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Fedders X Chassis A6X08F2A Air Conditioner Logo
257 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
