Question about Epson Stylus Photo R300 InkJet Printer
Fake paper jam
The status window tells me: ------------------------------- Paper jam or CD/DVD tray jam: For sheets of paper, turn off the printer and then remove any jammed paper by hand. For a CD or DVD, remove the CD/DVD tray. Next, press the Maintenance button on the printer or click the Eject button if it appears on this screen. ------------------------------- In reality, the paper is not jammed. The paper feed simply won't feed the paper beyond just behind the six little white rolls and the larger roll beneath that would grab a hold of the paper and pull it through. Does anyone know what to clean/tweak to fix this problem?
  • 2 more comments
  • thduggie Sep 30, 2007
    You are my hero! The object causing the invisible jam was one of those little plastic bits they use to fasten price tags onto clothing. It came out on the front edge of the card.
    Thanks, honestly. I'll take you out for dinner if you're ever in Switzerland. Write me at yo.stephan [at] switzerland.org and mention FixYa in the subject line.
  • Anonymous May 17, 2008
    Whenever I try to print, paper jam comes up on the screen but on visual inspection there is no paper jam in the the rollers
  • teddybear999 Aug 18, 2008
    Pretty much the same as everyone elses. It comes up on the screen with 'Paper Jam'. I've checked as much as i can and can find nothing stopping it. When i go to print a document it starts by loading the paper then lines itself up and just as the print head is about to move along the paper to print it stops and the maitenance light comes on with a warn ing on the computer screen. i have tried to press the maitenance button which ejects the paper but then reloads a fresh sheet and stops again. I then have to cancel the print. I've tried to print a test page but the same thing happens. However i have noticed that it will print the nozzle check page but nothing else will print. I then found on the internet a piece about the waste ink ctr,so i did that and still nothing. I have the ssc utility but still nothing. I live in an upatairs flat and i'm disabled. You are my last hope as I am sorely tempted to chuck it out the window.
  • Anonymous Apr 14, 2009
    Best solution- You are amazing I forced an old birthday card through my printer and you'll never believe this but I had a pencil stuck in my printer now everything works just fine thanks!!!
    Problem Solver:
  • 7 Answers
I am running Vista Ultimate SP1 x64 all updates and have been trying to sort out the fake paper jam on my Epson R300. I tried compressed air from my workshop compressor; believe me if anything was blocking the feed it wouldn't after I blasted it lol! anyway I also tried running some thick card through and still nothing, did some button pressing to get out of maintenance errors and all sorts of other things. I was about 5 mins away from reluctantly scrapping the printer when I happened across SSC Utility.
I downloaded SSC Utility, but there didn't seem to be much that would sort out the paper jam so out of curiosity I decided to click a few things and then test the printer.
The only thing I ended up Clicking was 'Reset Protection Counter' and that worked, it printed out fine.
so that was my solution, we'll see how long it lasts.
Posted on Oct 07, 2008
I WAS another with the same problem. If you ever come to Hobart, Tasmania I will take you for a free feed and tourist look as well :) Man have you saved me some stress Huge thank you. Was so simple.
Cheers
Shane
Posted on Jun 28, 2008
I had the very same problem unitl a moment ago!! I found some A4 card and forced it through the printer. I tried to print a document as usual, as the rollers (inside the printer) lifted, i pushed the card through in an attempt to clear any blockage which wasn't visible to me. It cleared the block and is now working perfectly again !! give it a go.
Posted on Aug 28, 2007
I have an OKI C3530 MFP that tells me to open the top cover due to a paper jam, but no paper anywhere. The machine was stopped in mid print and is now confused. Help!
Open the machine and remove the paper tray, the drum tray, the transfer belt and the fuser. Check all for a sheet or part sheet of paper. replace all and retry.If still register a paper jam have a look underneath to see if one of the paper pick up sensors is jammed open.
Jan 03, 2018 | OKI Office Equipment & Supplies
Tip
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
on Jul 14, 2010 | Office Equipment & Supplies
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    Paper jam dx7400
    Here's how to clear the paper jam,
    • Open the paper tray and remove all the loaded papers.
    • Open the printer cover and check through for any stuck papers and remove them manually.
    • Close the cover and turn the printer off.Wait a few minutes then turn it on.
    Now try to run a status print by:
    • Turning on the printer.
    • Load a paper
    • Press the right arrow > three times.
    • A status sheet is printed.
    Hope this helps.Thanks!
    Nov 02, 2011 | Office Equipment & Supplies
    Epson Stylus PHOTO R220 red lights keep flashing
    I hope this will help you :)
    * Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
    * RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
    * RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
    * RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
    * RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
    * RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
    * Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
    Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
    Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
    I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
    Nothing else for it with your, take the drum and toner out and check for bits of paper.
    Mar 11, 2017 | Brother HL-5370DWT Laser Printer
    Paper jammed
    Hi Good day!!!
    Here are some steps to remove paper jam
    1. Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands on the metal tools inside the chassis.
    2. Pin down the exact location of the jam. The three hot spots for a jam are before a sheet completely leaves the paper tray, between the feed tray and the print carriage or between the print carriage and the output tray.
    3. Take off the front paper tray. If the sheet jammed around here, you should be able to see most of the paper.
    4. Pull on the sheet with both hands and steady pressure. Don't tug too quickly. You might rip the paper, leaving a chunk of it deeper in the machine.
    5. Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
    6. Use the carriage access door to get at a jam further inside. You may need to move the print carriage out of your way to get at the jam.
    7. Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Thank you for using FixYa
    Don't forget to vote thanks!!!
    Nov 05, 2010 | Epson WorkForce 600 All-In-One InkJet...
    Red light on steady
    If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
    If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
    May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
    When printing paper continues to jam.
    1. Take out paper tray 1.
    2. Remove any jammed sheets of paper you find there.
    3. Once you have done this, reinstall the paper tray and try printing again.
      Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
    4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
    Dec 16, 2008 | Office Equipment & Supplies
    Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
    Hope this helps....
    Explanation of the paper jam message
    A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
    NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
    Clearing the jam
    To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
    Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
    NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
    For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
    NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
    Remove any jammed sheets of paper you find and try printing again.
    Dec 12, 2008 | Lexmark T640 Laser Printer
    Epson Stylus Photo R300 InkJet Printer Logo
    1,524 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
