Problem with Toshiba E-STUDIO 450 Copier
The copier keeps saying to put doc. feeder down and i it is. I ha
1 Solution
Don't know what is going on but in the readout box keeps telling be to put doc. feeder down when it already is. Once I open and it resets then place the doc in the feeder it gives me the same message again. Have to restart all over. It works fine when i just place on the glass and copy I have a toshiba e-Studio 45 and when it is on and warmed up it says Ready. However once paper is loaded into the ADF it says 'Please Place Document Feeder in the Down Position'. I have checked the sensors including the Platen Sensor as mentioned above in the 03 Input/Output mode and they are all functional. I think there is a problem with the Feed Motor and I was wondering if that might have anything to do with the Error the Control Panel is displaying.
  • avatar
    hayden du plessis Have you checked to see that the ADF is sitting 100% level (front to rear) and no skew. This can cause the sensor to misread and give that message.
    May 11, 2010
Guest
503 people viewed this problem
  • 3 people found this problem to be helpful.
  • 0 people are following this problem. Be the first!
More Insights on Fixboard
1 Solution
  • jaceyt
  • 1 solutions
  • Sep 04, 2009
This solution has been voted best by the Fixya Commnunity
Power supply has the fuse open that feed the voltage for the ardf
Add your solution
Full Name
Top Toshiba Copiers Experts
Rick Kasper
  • Solutions: 2072
  • Level: 3
  • Achievements: 1
Chris Coughlin
  • Solutions: 1229
  • Level: 2
  • Achievements: 2
Adorjani Laszlo
  • Solutions: 1142
  • Level: 3
  • Achievements: 2
Expert Badge
Are you a Toshiba Copier Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More E-STUDIO 450 Copier Related Problems
Loading... Loading...
