Question about Sony KP-61S75 TV
Kp-61S75 sony won't come on check for powerr ok unpluged let set stll nothing Does this have a fuse? were are the wiring schematic?
  • Anonymous Jul 12, 2008
    when pluged the power, power on and off with in a second.
  • Sonytuffa Jan 19, 2009
    My Sony kp-61S75 have the same issue. The power come on and off in the matter of second. No sound and no picture. What I need to do?
I have wiring diagram
Posted on Aug 29, 2007
SOURCE:
TV screen is cracked bad, need to find a cheep one
There is no other mach to Sony flat panel screens. If you wish to get a cheap one, you have to contact any service technician. Sometimes, he can give you a second hand one, for cheaper rate. There is no need to try to match an other screen with none of sony models. OK?
google.com/+GopakumarGopalan
Nov 26, 2013 | Sony KP-61S75 TV
KP61S75 has 45* angled stripes.
1? you must test the power supply, the absence of this cause a LOT of problem, test a= fuse, filter, c.breaker rectifier.
2) test the tuner, i-f, video detector, AGC, section
3) if the tv has external POT adjustment for vertical, horizon, do it carefully.
4) tight any wires connector loose, or bad contacts.
God bless you
see the diagram
Jul 18, 2012 | Sony KP-61S75 TV
Has no power ,won't come on.
follow power cord (set unplugged) to power board and the glass fuse there--check it first.
May 21, 2012 | Sony KP-46WT500 46" Rear Projection...
I have a Sony rear projection tv KP-57HW40 won't
Follow the power cord (set unplugged) into the set as it goes directly to the main fuse (should be 6.3 amp) and see if it is good or bad.
May 16, 2012 | Sony Televison & Video
Sony color video projector KP61S75 does not power on. Sometimes when you plug it in an outlet the red light comon and stays on with no sound or picture.
When the set does not power on does the red light blink? If yes then how many times does it blink in between each pause?
Mar 06, 2011 | Sony KP-61S75 TV
How do you adjust the picture? Mine is zoomed in
Is this set using a cable or satellite box? I looked at the owners manual and did not see any format adjustments. If it is hooked to a box, check the settings there.
Oct 14, 2009 | Sony KP-61S75 TV
3 yellow horizontal lines in upper 1/3 of screen on Sony KP-61S75
TV has problem in convergence circuit. Needs qualified technician.
Aug 03, 2008 | Sony KP-61S75 TV
Sony KP-61S75 TV Logo
266 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
