Question about JVC AV-28GT1B 28" TV
ADJUST HORIZONTAL HOLD
I gained access to the service area but I am not sure what to do to move the picture approx one inch to the left. Any ideas?
  • nickcc101 Feb 18, 2008
    Picture has moved to the right of the screen, have looked on the remote for the correct buttons to allow me to move the picture but unable to locate them.
    Problem Solver:
  • 5 Answers
Thanks for reply but which button on the remote is the display key. Have tried yellow button with picture button but nothing happens.
Posted on Feb 24, 2008
  • nickcc101 Mar 06, 2008
    Solved my problem by changing picture format from my Sky + sat box to RGB from PAL picture now ok. (UK)
  • 156 Answers
PRESS DISPLY KEY AND PICTURE MODE KEY SIMILUTONSLYON THE RECOTE CONTROL.
SERVICE MODE WILL APPEAR ON THE SCREEN.
GO TO DEF SETTING AEREA AND SHIFT BY PLUS OR NEGATIVE KEY.
Posted on Oct 27, 2007
SOURCE:
Toshiba 61H70
Does the rest of the viewing picture looks like the picture below?b66a18b.jpg
Jul 04, 2008 | Toshiba 61H70 61" Rear Projection...
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
RCA F27669 TV does not seem to have a Horizontal Hold. My picture has shifted about 2 inches to the left.
Generally speaking: go into the menu where you set up the colours, brightness, backlighting, etc.
Vertical/horizontal adjustments will be in there.
I can't find a manual online to be more specific.
Nov 16, 2009 | RCA F27669 TV
How do I adjust the headlights. I just bought
Generally on headlights, there is going to be 2 adjusting screws. You can tell them because they don't match the other screws holding the headlight in place. If you need to take off the outer ring to gain access to them. Stand the bike back around 30 feet and draw a horizontal line in tape ( usually against a garage door ) approx, 36" from the ground. Line up the headlight with that line and you should be good to go. 1 screw is generally a horizontal adjustment and the other is a vertical adjusting screw.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Aug 28, 2009 | 1998 Honda VT 1100 C3 Shadow Aero
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Diamond TV
The vertical height driver that controls the height of your picture has weakened and needs to be adjusted. If you are somewhat handy you can do this yourself. It requires that you gain access to back of the set & remove the cover. Once removed, locate the vertical height & centering adjustments. Sometimes they are located on the main board & other times are located on the color gun driver circuit board that is plugged into the end of the picture tube.
Respond to this post if you need additional assistance. Good luck!
Mar 14, 2008 | Televison & Video
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
My Sanyo DS24425 24 inch screen moves slightly to the left and stays there. its very frustrating because i play games on that tellie and cant see part. it's not parted halfway though. its like one a couple...
The problem can be corrected by only qualified technician. There is what is called the service man's menu which can only be accessed by a partciular code in service manual for that particular TV. Your local service technician should be able to locate the the manual and then perform what is caller a horizontal centering adjustment. In today's tv's there are no alalog controls for easy adjustment, it all done with eprom ic which allows the manufacturer to use the same chasis for many different picture tube sizes. If you could get manual. and have basic computer skills , you could probably do it yourself. You might try ordering the maual from Tritrinics/Cititrinix 1-800-638-3328. Scrivitron
Jun 29, 2007 | Sanyo DS24425 24" TV
JVC AV-28GT1B 28" TV Logo
316 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
