Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
Will not spray
My Little Green Machine will not spray any solution. I used it about 6 weeks ago and It worked fine. I went to use it the other day and it didn't spray. The machine turns on and the heating function seems to work. I called the Bissell customer support line and I followed their instructions on cleaning and priming the lines inside. Both steps didn't solve the problem. Any ideas Thanks
  • 6 more comments
  • dvs33 Dec 10, 2007
    Same Problem!My Little Green Machine will not spray any solution. I used it about 6 weeks ago and It worked fine. I went to use it the other day and it didn't spray. The machine turns on and the heating function seems to work.
    How can I download a service manual?
  • Anonymous Feb 09, 2008
    will not spray
  • cvinny Mar 22, 2008
    In the middle of cleaning it just stopped sprayed tried cleaning out the brush refilling the solution.
  • Anonymous Apr 02, 2008
    Does not spray. Took the handle apart the tube seems fine but the cleaning solution does not reach to the handle
    I took apart the handle. The tube seems fine but the solution does not flow to the handle
  • ccw2 Dec 02, 2008
    the machine doesnot spray or seem to go to the proper drainage container
  • Anonymous Jan 06, 2009
    I also have the same problem. I consulted my manual and tried every "solution" that Bissell offered. I even took apart the hose and "cleaned" out the waterline w/ pipe cleaners. This resulted in getting a small stream of water to go through. I wondered if I would "kill" the machine if I were to attempt to run a weak solution of hot water and CLR through it???
    Kristen "the female McGuyver" lol
  • PETE GALATI
    PETE GALATI Apr 08, 2009
    IHAVE THE SAME PROBLEM BLEW THROUGH ALL THE LINE SEEM TO BE CLEAR.IS THE PUMP IN THE SAME PLACE AS THE HEATER
  • 281 Answers
Sounds like the pump is bad.how old is it.you should have at least a 1 yeay warranty on it.if still under warranty take it to a dealer that repairs bissell along with your reciept.if you don't have the reciept thats ok they will go by the serial number ,that will tell them of the warranty status
Posted on Apr 29, 2009
Try some after use care, namely, running clean, hot water through the line, then removing the supply tank and running until no water comes through. This will help but will not elminate the problem. In addtion to heater clogging, the pump may seize up, also.
Mike
Posted on Sep 04, 2008
I have had to take mine apart every time I use it. The passages in the heater get clogged with cooked soap residue and this keeps the fluid from flowing properly. The crystalized soap has also plugged the tube in the handle, and the attachments, quite a few times. I am now having trouble with water leaking out the bottom when running the cleaner. I have traced this back to the heater. It seems that the soap, or something, has eaten a couple of holes in the removable metal cove that seals the back of the heater. This is the same cover that I have had to remove quite a few times to clean the passages out. I have fixed this temporarily, but now I need to order a heater assembly, as this piece is not sold separately. I like the machine and the way it cleans, but it sure has its share of problems. Hope this helps somebody. One way I found to slow down the heater plugging up, although it still does it eventually, is to make sure I have fluid coming out the attachment before turning the heater on. It seems to cook whats in the heater less.
Posted on Aug 29, 2008
Same thing, will not spray. Is it possible a worn flapper valve could cause the same problem? I put it in bachward once & it didn't spray till reversed. It's in propoerly now, but it seems worn (doesn't close completely) I'm wondering what function the flapper valve in the feed tank serves.
Posted on Mar 21, 2008
I have the same problem. I took it apart and found that the water pump had leaked and burned out the water pump motor. It's a $20 part.
Posted on Sep 01, 2007
Little green machine will not spray cleaner
Have you checked the tiny hole that the spray comes out of. I have one and sometimes it becomes clogged. I take a small needle and run it thru it.
Oct 09, 2014 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Little mean green machine sprayer is not spraying
It might be clogged up from being used so often? Try getting some pipe cleaners and running them through the spray holes where the "solution" comes out.
Apr 05, 2014 | Bissell Vacuums
Spray path is too wide. Is there a deflector available
I had the same problem with my proheat. The water would spray a wide path out the sides. I think it must be a defect as I have replaced my unit due to another problem. I purchased the Bissell machine without the heater and the nozzle is fine.
May 14, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Bissell little green machine will not spray
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
Mar 22, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on...
I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
Manufacturer's Part Number: 6035029
If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
Try this direct link to VacPartsWarehouse's website:
VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
Good luck! :)
Dan
May 29, 2009 | Bissell 1400 Little Green Pro Canister...
My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
I also had the same problem as you.
Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
I did this a couple of times and it worked. This info I found on the Bissell website.
Good Luck!
Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Bissel Little Green Spray Motor
Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
Mar 09, 2008 | Bissell Vacuums
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
1,126 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
