Question about Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver
Signal dropout on 1 of 2 tuners
One of the two tuners on the DVR is suffering from video and audio drop out that is very similar to sat signal interference resulting from bad weather. The other tuner is unaffected. This problem manifests itself on both live and recorded video from that tuner. Swapping the incoming video lines has no effect on which tuner is affected.
  • MaximoTV Nov 25, 2008
    My video drops out but when I re-power the box, the video comes back. This problem only happened occasionally but now is occurring a few times a week (twice today). I think my DVR unit needs to be replaced. Thoughts?
  • tpierson77 Feb 24, 2009
    The receiver losses it's signal sometimes and the message says
    searching in satelite 1 for satelite 2. and sometims I get interference
    on the screen like when you have an electrical storm. Also the
    picture on both sides of the screen starts to turn red. If I turn the
    Tv on and off it goes back to a normal picture. Do you think it is the
    receiver or the satelite signal.
I had the vary same problem, One solution is to remove the s-cable and use the analog video out, I have read lots of forums about this, it works for most people, No one seems to know why the s-cable causes pixelation on sat 2 input, and can't find anybody that can fix it completly, check forums at weak knees.com and tivo comunity. Good luck. ddftoc.
Posted on Dec 09, 2007
Oops forgot that I already posted the fix. However, the VCR recently failed all together and has been replaced. Also, I have since moved from DirectTV to Dish due to a separate and unrelated problem with the dish.
Posted on Dec 10, 2007
My problem was the result of a grounding problem on another, connected piece of equipment. When that item was disconnected the problem was resolved. Thanks for the responses.
Found the problem...it looks like a grounding issue between several of the components in the setup. I disconnected the AV connections to the VHS deck from the DVR and the problem went away.
Posted on Sep 17, 2007
    Genius:
  • 1,139 Answers
This denotes a problem with the RF tuner itself, which if it is a module it can be replaced, however if it is an actual part of the main circuitry you will have to have the whole unit replaced. Tuners are not user fixable since it contains many components that are very sensitive. I would suggest either having the unit replaced or taking it to a TV repair shop which is setup for such repairs.
Posted on Sep 16, 2007
Is there any way to get Zone 2 to take the same source as Maine 1? My Zone 2 does not paly anything from cbl/sat even if zone 1 is on tuner
What kind of signal are you using for the cable/sat? Most receivers cannot use a digital input (optical, hmdi) to output a signal to zone 2. You may have to make an analog connection to get it to work.
Jun 13, 2013 | Sherwood R-925
When watching sattelite tv I get what sounds like artifact sounds that come through. They are very loud, best described as a "TINK". It is very annoying listening to Tink, tink, tink tink, tink...
Not knowing the specific cabling you use and the pathing...
Everything is digital. You're probably experiencing data dropouts.
Is the problem both audible and visual? THAT would point to data loss where the video and audio coexist - upstream of the TV and audio systems. If it just the audio medium, analyze its physical sugnal path and see where you can isolate or eliminate cabling and hardware. The ONKYO has indicators that would blink upon digital signal loss. Trace it back from there.*
* I always run the BEST video from each source directly to the TV and the BEST audio directly to the electronics. Unnecessary interconnects and hops are expensive and failure prone. Optical cable should be routed with lazy curves to avoid light loss and data dropouts.
In many systems with a DVR ALL viewing is from the DVR rather than LIVE.
Observe whether a given glitch is observable and repeatable on your DVR. If it IS, the transmission was bad at that moment and the result was captured. From this point there is no way to differentiate between bad data IN or bad data from the Hard Drive, unless you can bypass the DVR entirely or watch it truly LIVE.
If you have support for the DVR, the vendor CAN log into it and examine its error log data.
Mar 15, 2011 | Onkyo TX-SR705 Receiver
Tivo Series 3 TCD652150 has has a blank display on Tuner 1. Tuner 0 works fine, and Tivo menus will display on Tuner 1 so I assume tuner 1 is not processing the audio/video signal. I feel I'll have...
The Tivo Series 3 uses two CableCards, one for each tuner. It is possible that the CableCard that is responsible for receiving channels on Tuner 1 is defective, has become corrupted, or otherwise is not paired correctly. Call your cable provider and have a tech look at it.
Jan 16, 2011 | Tivo TCD652160 180-Hours HD DVR
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
Trouble with Tuner 2
From experience, I suspect that the dish has lost it's optimum "focus" on the satellites, and your signal has dropped. In your case, tuner #2 just happens to need a little more signal than tuner #1 - and that's revealing the root problem.
If you can have a second person handy, use the signal meter function and view the signal. Then one person should move the dish a bit (likely upward a hair). If the signal goes up with just the slight movement of the still tight dish, that's the problem.
If so, it's time to align the dish.
May 14, 2008 | Samsung SIRS4120R Receiver
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Open Questions:
Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver Logo
254 people viewed this question
Top Hughes Televison & Video Experts
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
