Question about Samsung SC-D353 Mini DV Digital Camcorder
LCD panel Suddenly there is no image just a series of lines
Replace lcd ribbon cable.
Posted on Sep 04, 2007
Suddenly I have double images the bottom 2 inches of the screen they are accompanied with wavy lines but function with all activities as normal, what can cause this?
The TCON board or thr LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 08, 2017 | Televison & Video
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
A very, very thin vertical red line suddenly appeared on the television screen
You have failing LCD panel, see my troubleshooting guide pictures of bad LCD panel, I hope you have extended warranty on your TV! You will get more lines as time goes by.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 06, 2011 | Vizio VO47L 47 in. LCD TV
My Starlogic M17ANA Monitor suddenly gave a screen that was 3/4 white with a lot of vertical thin colored lines. The part that is clear shows normal monitor image. I even took some pictures of it that I...
That is the failing LCD panel, nothing you can do.
See example of failed LCD panel in my guide and in my albums.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 31, 2010 | Star Logic 17" LCD Monitor
My TV suddenly has 2 7in horizontal lines on the same level seperated by 18in of good image. It doesn't matter which input is used or if it is cable, dvd, or video game.
same issue here. started with one line about 4" down from the top, then another appeared 4" from the bottom a month later, now another month and another line near the center.
Aug 09, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I suddenly have white horizontal lines in the picture.
If it is Canon A95 camera then it has problem of bad ccd Image and needs to be replaced that part.
Canon will repair A95 for bad ccd Imager problem free of cost.
Please click Canon ccd Imager advisory for details.
Feb 10, 2009 | Canon PowerShot A95 Digital Camera
Astar 19" LCD TV
Please call 323-767-6030 I will help you resolve your problem.
Aug 27, 2008 | Astar LTV-3201 32 in. LCD Television
PSP suddenly has vertical lines no image
For your first PSP: there is a loose conection of LCD Screen with the motherboard and the solution is as follow: You can open the PSP and just lift the LCD Screen up be sure before lifting LCD Screen one thin Switch panel of micro buttons Home,VOL,select etc, you have to remove this first then only it is possible to lift the LCD Screen and after that you check that broad connection strip which is fixed with the motherboard socket you remove it this strip and refixed it again,your problem should get solved if suppose your LCD Screen is not broken.
Sep 02, 2007 | Sony PlayStation Portable (PSP) Console
Samsung SC-D353 Mini DV Digital Camcorder Logo
88 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
