Question about Panasonic Microwave Ovens
Turntable wheel under glass tray broken
Can I still use microwave if the turn table wheel that turns the glass tray is broken. Sometimes the wheel if put togehter where broken is laid just right it turns. But sometimes it doesnt. Can I still use microwave without the wheel in place to make the turntable glass tray turn. Afriad might burn out something Panasonic model # NE 6860 Serial # K08799
  • Anonymous Mar 29, 2014
    spinner under the glass table is broken
  • 276 Answers
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Posted on Mar 31, 2009
SOURCE:
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
Microware trun table does trun
Try to turn the turntable coupling under the glass tray by hand it should be pretty hard. If not, you may have a broken coupling. Those are plastic with a D shaped hole in them. If it has cracked, or broken, the motor cannot turn it. So either a bad coupling or a bad motor.
Oct 09, 2017 | Microwave Ovens
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
Turn table turns some of the time
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Walesarumi
Sep 26, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
The turn table doesnt work
Good luck.
Mar 12, 2011 | Daewoo KOC-925T Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
My turntable quit turning, I looked in and found a what appears to be a piece of what looks like glass that acts as a shaft between the motor and the turntable was broken. I cant find the part or any...
If you are talking about the little piece that the center of the tray sits on (not the carousel ring), its called the coupler. Its actually made of plastic on all the microwave ovens I've ever worked on. I've never seen one made of glass. It connects to the turn table motor shaft. If you post back with a complete model number, I may be able to assist you in locating a part number.
If the coupler is not physically broken, you may be identifying the wrong part as your problem. The turntable is driven by a small motor which is mounted under the bottom panel of the oven. The coupler is mounted to the shaft of the motor and the glass tray sits on the coupler.
Post back and let me know if you need a coupler, or if your motor isn't turning. You can tell by removing the glass tray and pulling straight up on the coupler. It should come off the motor shaft in one piece. If its not broken, your motor probably needs replaced.
Sep 09, 2009 | Microwave Ovens
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
Microwave Ovens Logo
890 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
